Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Refrigerator making loud noise and fan: help!
My hotpoint top freezer/bottom fridge refrigerator is making a very loud clanking running sound for long periods of time. when I open the freezer door, I can hear the sound louder inside of there, and the fan is blowing hard.
I feel like there's something wrong because it's never been this loud before.
what should i do?
  • Anonymous Mar 12, 2014
    Loud humming noise when it kicks on and the veg. tray freezes stuff
  • Anonymous Mar 24, 2014
    bottom mount freezer door was left open over night and wasn'y open until recently to take food out. Loud noise. HELP!!
    President:
  • 1,462 Answers
Take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Posted on Jul 18, 2008
SOURCE:
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Made a loud noise from fridge(fan) now will not get cold
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 13, 2011 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer fan makes loud humming sound
sounds like the bearing in the fan motor is gone. need to replace it.. ok
Feb 12, 2011 | Hotpoint HSS25GFP Side by Side...
My fridge is making a loud noise that sounds like an air compressor.
The defrost is not working and ice has built up and is hitting the fan...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 20, 2010 | GE PTC22MFM Top Freezer Refrigerator
A loud humming sound is coming from the freezer section. What should I do?
Ice build up hitting the fan???
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 08, 2010 | Hotpoint HTS17BCSR Top Freezer...
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Loud clanking noise when washer is coming to a stop
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
1,827 people viewed this question
Top Hotpoint Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Jose Pino
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
