Question about Intel Motherboard
Looking for a mother board
I was taking out a graphic card and while tring to loss clip, i bent something thinking it was the clip. the computer turns on , but nothing on monitor. can this mother board be repair? and if not where do i find this motherboard ( Intel (Augsburg) No CPU. )? please help, david
  • Tim Babcock
    Tim Babcock May 11, 2010
    What kind of processor are you using and do you know what the socket type is?
  • 807 Answers
Have a look on the m/b for the make/model number, then have a look around the internet for a replacement. EBay is as good a place to start as any.
Posted on Jul 18, 2008
I'm thinking it might be the video or graphics card on my desk top ive tried several different monitors and nothing no error message no windows logo all the ports and cables are fine nothings broken
if it has a separate monitor connection on the mother board at the back, pull the graphic card and connect to the monitor to that connection
If it is a graphic card , the mother board card will run the monitor so replace the graphic card
if you do not have a plug in graphic card and that is how you have it set up take it in for a proper diagnosis as it may be the mother board is failing
Mar 18, 2017 | Graphics Computers & Internet
My Gateway FX 7026 goes "Black Screen" upon start-up and nothing happens.
The video is out.If you have a video card,replace it.For now you can run graphics off the mother board.To do that.Turn the computer off and unplug the power.Look on the back of the machine find where the monitor is connected.There are two places to connect a monitor.The first is kinda high on the machine and is blue,if you are already plugged in to the blue one the mother board is bad.Take it to a shop for repair,or buy a new computer.If the monitor is plugged into the white slot you have a bad graphics card and need to replace it.
Jul 13, 2011 | Computers & Internet
I have an HP S3000 Slimline computer with no graphics, the monitor is blank, no beeps and the power light on the monitor is yellow. I checked voltage going to some of the hardware and it is 10.5 volts and...
is the monitor ligt blinking or solid light if the monitor light is blinking remove the covers then remove the memory card and clean them with a clean cloth and insert in the dimmi socket and switch on the monitor light will be steady and still you have problem replace the memory and also look for the graphics section mostly the graphics is embedded to the mother board if you are having pci express slot or agp slot you can insert a graphics card and check if you have graphics that mens the embedded graphics section in *********** board is fried you can take the mother board to to a chiplevel service person for repair or you can use the add on graphics card
Mar 16, 2011 | Computers & Internet
MY PC Desktop won't boot up, in the back off the tower a clicking green is blinking ,and on the motherboard is also a green light blinking ; i think it is the power supply What i did before this was...
First of all this might sound silly but when you say (turn it back on disconnect my old graphics card on safe mode) did you actually pull out the graphic card from the mother board while POWER WAS ON??? if so you definitively damaged something (the mother board or the power supply) to check you could try an other power supply if it still wont work than it's the mother board, now if I've miss understood your question it sounds like a SHORT CIRCUIT somewhere on the board check for lost screws that could have fallen and running loosely on the mother board while changing your hardware...
Hope this helps!
Feb 09, 2011 | Sony VAIO VGC-RB43 PC Desktop
Switch on computer and message on monitor says no signal input. think it might be the graphics card but can't test because not compatible with old computer mother board
This is more likely to be a problem with the connection between the graphics card & the monitor. The connection might be loose at one of the ends. Another possibility is that the cable connecting the graphics card & the monitor is damaged & needs to be replaced. Also, it might be because of a damaged VGA socket. Check the VGA socket for broken or bent pins.
Oct 31, 2009 | Pine Technology XFX GEFORCE 7600 GT 256MB...
Wires off graphics card into mother board?
The computer won't boot if there is no graphic present. If you did hook it up right and there is a fan on the graphics card, it should be turning.
Oct 17, 2009 | Gateway Computers & Internet
Vista HELP
with the 64 mb graphics card i dont think that u can run VISTA if u want to run Premium version u need to get a higher graphics card atleast 128 Mb or above and for 1 gb graphics card pls check the manual of ur card first b4 buying it bcoz ur mother board may not support it but its a rare case when this happens but pls check b4 buying or let me know with the exact brand and model u r going to buy i will check it for u
pls rate me fixya if i have answered ur question
Mar 03, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Help
Circuit boards are very easy to mess up, and usually if something like that happens, other dammage that is not easily visible can occur. Thoroughly inspect the board for anything that looks unusual. Something else in the board may be fried along with a list of other potential problems. The bus (small metal strips on the bottom) may be broken or shorted as well. If it is an expensive card, you can take it to a repair shop and they can possibly fix it (no guarantee) or you will probably have to replace the card. If you have any other questions, let me know. Hope this helps.
Jan 20, 2009 | Nvidia GeForce 6800 GT, (256 MB) Graphic...
My Computer
OK. Thanks for the response. That message is telling us that the monitor is getting no signal from the computer. In your case, it sounds like it is working part of the time. So, here are the things that can cause the problem, starting with the monitor and working backwards.
1) The monitor may have an internal problem.
2) The cable connector that goes into the monitor may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
3) The cable itself could be damaged and have a wire that is cut or pinched. Look for cuts or heavy crimps on the cable.
4) The cable connector that goes into the computer may have a loose connection or be bad. Check for loose or bent pins in the connector plug and socket, and that the plug is seated properly and is tight.
5) There could be a problem with the computer that is internal. If there is a video card that plugs into the mother board, you could unplug it, clean the dust and such from the contacts on the card and around where the video card plugs in the mother board and reinsert the video card. Also, the video card itself could be bad,in which case it would need to be replaced. Some systems have the video function as a part of the mother board. If that's the case, the mother board would need to be replaced.
One thing that you can try when it is failing. While watching the monitor, firmly wiggle the cable and each of the connectors to see if the signal comes and goes. You may want to enlist someone to watch while you wiggle, or wiggle while you watch (That sounds kind'a bad doesn't it? <Grin>) But, that could tell us something.
Hope this helps and will be waiting to hear back from you on this.
Ron
Dec 16, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Intel Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
