Question about HP Office Equipment & Supplies
Hp 9130 printer
Tray #2 paper always getting stuck two out of three sheets the paper get stuck
  • 186 Answers
Pull out the paper tray and look where it is getting stuck to make surre there is not a small peice of paper in the path that is causing the jam. Also clean all the rubber rollers in the tray and where the tray fits in with some rubbing alcohol and a cloth. Make sure you fan the paper thoroughly before loading into the tray. The humidity causes the pages to stick together.
Posted on Jul 18, 2008
HOW TO REMOVE BLOCK PAPER
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Oct 26, 2010 | HP LaserJet 1320 Printer
"Paper Jam" message displays despite there being no paper jammed. I have cleaned all the rollers and inspected as much as I can easily get to. Is there an easy fix or should I shop for replacements?
Oct 21, 2010 | HP PSC 750 All-In-One InkJet Printer
I have a HP Laserjet 4250 that is printing dirty prints. I have replaced the toner and the fuser unit and cannot correct the problem. I have 2 of these printers and the toner and fuser unit works no...
Try printing from the manual feed tray(tray 1). Put a few sheets of paper in the tray. Print anything that is more than two or three sheets of paper. The paper path test is good, 10 sheets. As the paper gets about halfway into the printer, open the top door. Pull out the toner cartridge. Look down at the paper. If it's dirty it has to be the toner or the transfer roller. If it's clean it could be a dirty paper path or fuser.
Vacuum out the printer, if you have mounds of toner laying in the paper path, everything that comes out of the printer will be dirty.
Aug 02, 2010 | HP LaserJet 4250n Printer
The paper is jammed. How do i get it out?
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jun 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
HP j5780 printer sends "paper jam" message AFTER it prints one page. there is no apparent jam in all the places I have looked. I am in need of a repair manual (not an owners manual).
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 12, 2010 | Office Equipment & Supplies
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
Paper jam in fax how do I clear?
folow the instruction
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    It has paper jam some times on the begining of trasfr belt sometimes middel of that and also it send two diffrent error messages 13.01 and 13.09?
    1. 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    Apr 20, 2010 | HP LaserJet 5550 Printer
    Paper feed problem from both tray 1 & 2
    There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
    Feb 17, 2009 | HP LaserJet CP3505n Printer
    93 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
