Hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
REMOVE THE OLD 2. LEAVE COVER OPEN AND REMOVE THE PROTECTIVE COVER ON THE NEW REPLACEMENT 3. INSERT THE NEW INTO THE SAME CARTRIDGE INSERT AREA 4. RESET YOUR PC TO NEW CARTRIDGE INSERTED 5. YOU WILL BE PROMPTED BY YOUR SYSTEM TO INDICATE IF A NEW CARTRIDGE HAS BEEN INSERTED 6. NOTE THE COST OF THIS TYPE OF PRINTER (MAINTENANCE) IS MUCH HIGHER THAN THAT OF THE LLASER PRINTER
