Question about Microsoft Xbox 360 Console
Dvd will not open
You can hear the motor wanting to open the dvd part but its stuck and will not open what can I do to fix this?
  • 116 Answers
Get a flat head screw driver press the open buton on the xbox and use the srewdriver to open it
Posted on Jul 18, 2008
My draw will not open
Hi, If you hire sound of motor (when you push the switch) who open the door then is rubber band on wheel inside DVD, or cd is stuck inside. In that case you can hook door with something and pool up easy! If no light on displey, or don`t hear motor (when you push the switch) then is electronic circuit in DVD, then you must go in service.
Good luck.
Feb 27, 2011 | Philips DVDR3440H DVD Recorder/HDD...
DVD tray is stuck. No DVD inside. I've removed top cover and there is no obvious mechanical obstruction. I can hear the motor attempting to move the tray but there is no movement of the tray or other...
Helo tom,
According to your problem description, it seems to be the problem with the DVD door mechanism. To fix the issue door mechanism, you have to replace entire mechanism think it helps! Let me know.
Best Regards,
Chandrashekhar Bhat
Dec 25, 2010 | GoVideo DV2130R DVD Player / VCR Combo
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
I have a Duraband Portable DVD player i think model 9PVS-1966) I can hear the dvd whirling but there is not picture....
sounds like the imager is bad, if you can see the menu thats good news. open and reseat all the ribbpon cables conneected to the lcd
Jul 10, 2009 | Durabrand PDV-709
Will not open
The motor that open the door has probably died. This is a common occurrence with cheaper DVD players. You will probably have to buy a new one.
If there is a disc stuck in there, you will have to remove the screws underneath and open the case to remove the disc.
Mar 25, 2009 | GPX D1816 DVD Player
DVD is stuck in Disc tray, will not open
I have a Phillips DVDR3390/37 and was getting a BLOCKED message. I found that by utilizing the slot on the bottom of DVD and moving the mechanism slightly to the left, it would open the DVD tray. The white plastic you see through the slot is part of the motor driven mechanism that raises the DVD disk up to the drive wheel that spins the DVD. The opening and raising actions are interconnected mechanically. I suspected the motor was going, so I unsoldered its black and red wires fom the small printed circuit board and removed it by also removing the two small screws on top. The board has a + mark and this is the red wire, remember which wires go where. (Might not be red and black.) I tested the motor with a flashlight battery and it seemed to run OK but didn't spin very long. This is a very small motor without a lot of reserve power. Removing it allowed me to oil the top bearing, the only one you can get at, as the bottom bearing is not open. You don't want oil all over the pulleys and the rubber band that rides in the pulleys and you have very little room to get the oil in under the plastic pulley. I used automatic transmission oil, a fine lubrican for a lot of things. This only takes about 1 drop of oil. If you get oil on the pulleys or belt, clean them with alcohol. This procedure fixed mine. Hope this helps.
Feb 20, 2009 | Philips Televison & Video
DVD DOOR WILL NOT OPEN YOU CAN HEAR DVD TRY TO OPEN
the dvd or game could be stuck. try turning the console upside down and eject the tray. or try tilting it to the sides and eject it. if all else fails then you might want to open it up and manualy eject it because its a pc dvd drive so you can pop the xbox tray guard off and stick a paperclick in the hole and push into the mech to pop the tray out to retreave the dvd
Jan 22, 2009 | Microsoft Xbox 360 Console
DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Aug 28, 2008 | Audio Players & Recorders
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
