Question about Hitachi P42H401 42 in. Plasma HDTV
TV will not turn on. The lights on front of TV are not lit either(power saving, stand by light). I checked the cord and have power coming in to the back of the TV.
    Scholar:
  • 145 Answers
Hello there,
Step 1: check all connections redoing them if needed mean remove the cables and plug everything back in .
Step 2: check the plug, plug something you know works into the plug to Test it
if the plug has power plug the TV back in and try the front panel button to turn on the TV if the TV still doesn't turn on let me know and we try a few more steps
Thank you don't forget to Rate
Posted on Jan 25, 2011
SOURCE:
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony tv will not power up
if no stand by light indicator, it was a power supply board failure. check for blown primary fuse .
Aug 17, 2012 | Sony KDL32BX300 32 in. TV
Tv not turning on
May I know if it has a led light at the front panel? Also, please confirm if your model no. is VW37L.
Oct 04, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a 50 Inch Vizio plasma High Def. and it turned off while I was watching it and it will not turn on again. I have tried unplugging it and powering it down, but nothing is working.
Hello
Will you please inform me some more details of the fault? Is there power indicator at the front panel of your TV? Or it is completely dead? Give me these details too please.
Sep 25, 2011 | Vizio VP50 10A 50 in. Plasma TV
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture no sound will turn on but not off, red light comes on
When the red light is lit press both the menu and device buttons in on the front of the set in together and hold for 5 seconds then record the two digit blink code that will repeat. I am assuming you will receive a 34 error or a 41Error. But let me know what blink code you get and I will assist you.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hitachi P42H401 42 in. Plasma HDTV Logo
185 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
