Problem in my speaker........
I have problem in my speaker of my computer.....so i check the control panel then i try to solve it.....but did not works........ my i help me.........plsss!!!
    Sergeant:
  • 291 Answers
Goto CONTROL PANEL>Sounds & audio Devices(icon). goto VOLUME, far left menu option.Just under VOLME you should see a ICON of a speaker & the name of the audio device\driver. [If you don't u don't have a audio device INSTALLED] Make sure that the MUTE is not checked.,place a check ['place volume icon in the taskbar] ( that is the RIGHT bottom)On the left bottom of the same"volme" click "speaker volume" and raise the volume. GOTO >SOUNDS(sbmenu)>program events(windows>Asterick,Close Prgram,critical Battery Alarm,Critical Stop,Default Beep,etc,etc)
UNDER:: sounds, look & see if a sound is "taged", just to the right there is a "right" arrow that should be BLACK. When you touch the "arrow" the sound that u "taged" should sound.(1st) goto AUDIO >Default device: you HAVE to see some type of "audio device" e.i. Sound Blaster, Conexant AMC ,ABC Bananers,some type of audio device! If not, left click mouse DARK "arrow" down to see if you have some type of adio device\driver.If so chooze it.(2nd) goto VOLUME AND raise the volume.(3rd) Go back to "sounds" & while you click the dark arrow facing right, connect the speaker jack to the back of the "FEMALE" port.Sometimes they are not marked and you could connect to the wrong port.example: mike in instead of speaker out. understand!
Posted on Jul 20, 2008
Volume loss
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hope this helps
Nov 10, 2012 | Audio Players & Recorders
Why my pc (ms915ep-mastonic) not detect the sound after installing xp window. sir plz solve it plz
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 31, 2011 | Matsonic MS9158EP (DSMTSMS9158EP)...
No sound after installing the sound driver help me to solve ..
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 27, 2011 | VIA ASUS P4V533-MX MB P4M266A/ Audio/ VGA/...
Please help me solve a satellite sound problem with my creative sbs a200 2.1 speaker system. I get sound from the subwoofer but the twoo small speakers have no sound. Any idea which component(s) to replace...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Logitech X240 speakers which worked well before give no sound at all now. Power is delivered but the amp seems to be malfunctioning. Two speakers are OK because when directly connected to my laptop...
also
hope this helps
Jun 05, 2011 | Logitech Audio Players & Recorders
My problem is my desktop no sound and audio device
also
hope this helps
Jun 03, 2011 | Computers & Internet
My ATP3 suddenly making some noice (Not all the time) when not in use (No audio is playing; but power is ON). During the time of play speaker volume falls into lower level and shift into normal level. ie,...
if you are having problems with your sound
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 07, 2011 | Altec Lansing ATP 3W Computer Speakers
My speaker on my computer don,t work what can i do to solved the problem.
see if you broke the wires see if they came unpluged make sure that they are in right hole it sould be in green hole or the speakers went bad that all i can think of jim or sound card is bad
Mar 28, 2011 | Computers & Internet
My left speaker has a flutter sound. In and out.
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 23, 2011 | Bose Companion II Computer Speakers
MY COMPUTER HAS NO AUDIO DEVICE I SEARCHED ON THE INTERNET BUT NOTHING WORK OUT PLS HELP ME TO SOLVE THIS PROBLEM
mcdevito75 here, Most Computers (Desktop) have built in Audio devices but you"ll need outside speakers, and you have to mke sure the audio is on in your computer. ----- Try this, in your computer click on start, then Control Panel, then on audio speakers devices, then un--check the MUTE box and Check the Place icon in the task bar box. Then hook up speakers to your computer, speakers available at Staples, Radipo shack etc.
Jul 02, 2010 | ASUS P5P800-MX Motherboard
 Grubhead
Grubhead
