Question about Whirlpool Washing Machines
Washer doesn't spin or spins slowly. - Whirlpool Washing Machines
  • 481 Answers
It could be something stuck between the tub and basket, like a sock. or it could be the clutch worn out.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 18, 2008
vest6
  • 196 Answers
SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Posted on Jan 12, 2008
  • 6 Answers
SOURCE: series 80 kenmore washer..doesn`t spin..
Make sure belts are still atached. Belts are relatively inexpensive and eazy to replace yourself.
Posted on Jan 14, 2008
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
  • 128 Answers
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Posted on Nov 22, 2008
  • 6 Answers
SOURCE: washer does not spin clothes - only slowly or not at all
I resolved the same problem yesterday. Funny, it did not cost a penny to fix. After moving the machine away from the wall I noticed two screws that were laying there and after removing the body of the machine found that only 1 of the 3 screws that were holding the housing (for what I assume was the transmission or belt drive) was still in place. I screwed in the 2 screws and it worked fine again.
Posted on Apr 27, 2009
FRIGIDAIRE LTF2140FS1 SPIN SLOWLY
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Feb 21, 2015 | Frigidaire Washing Machines
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
The washer doesn't spin
Possible that the belt is slipping due to overload, check the capacitor to the motor , check the belt to the motor, check if the spindle is jammed , if so reset the spindle.
Jan 18, 2013 | GE WBSE3120B Top Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Thanks in advance, my washer fills with water but doesn`t spin. not any noise.
The safety interlock switch might be bad. That's a safety switch to prevent the machine from agitating or spinning while the door is open. Close the door slowly and listen for a click just before it is completely closed. If you don't hear it, then check the alignment of the door and its actuator. If you do hear a click but the machine doesn't start, then the switch may need replacement.
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Washer spins slowly
your clutch pads are worn out they sell a kit to repair that
Feb 04, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will only spin with light loads. When
I replaced the clutch and the problem seems to be fixed
May 13, 2009 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
