Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My 96 vulcan 1500 ran well until i parked it hot on a hot day for 1/2 hr. then it flooded and would not start. i shut off the fuel and got it to start and had to run it at high idle (read 2000rpm or better) to get it sputtering and lurching home. it has backfired on decel ever since install of new pipes, but never this problem. what must i do?
  • 216 Answers
Check for a clog in u're venting system, loose float bowl screws particle contamination in inlet.
Clean and adjust float aseembly
Posted on Jul 22, 2008
1999 Vulcan 1500 will not start when engine is warm
Hi, Mary and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. Faulty starter motor.
5. Valves adjusted too tight.
6. Spark plug gap too wide.
7. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
won start up after its warm
Hot starting problem
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1999 Kawasaki Vulcan 1500 Owner Manual
Aug 15, 2017 | 1999 kawasaki VN 1500 Vulcan Classic
I have a 99 kawasaki Vulcan 1500 classic when I try to start it it will idle for a few until it floods the back plugs and it spits gas in air filter can some one tell me how to fix my problem
Hi, Brandon and the usual suspects are:
1. Dirt or other foreign matter between float valve and its seat.
2. Float valve sticking.
3. Float valve and/or valve seat worn or damaged.
4. Float misadjusted.
5. Float cracked, leaky or damaged.
6. Excessive "PUMPING" of hand throttle grip.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Flooded
Taking apart my carb
Kawaski Vulcan Carbs
Carbs leaking Here is how to fix it
http://www2.vulcanrider.se/DL/KawasakiVN1500_87-99ServiceManual.pdf
Apr 27, 2016 | kawasaki Motorcycles
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Jul 20, 2013 | Cars & Trucks
I started my bike it ran for a second and stalled when I tried to start it again it wouldn't start. I already replaced the battery what else could it be/
They are real easy to flood . Try changing the spark plugs. It is fuel injected do not give it gas when cranking to start or it will flood.
Sep 22, 2010 | 2001 kawasaki VN 1500 Vulcan Drifter
1500 kawasaki vulcan leaking gas into cylinder
could be 2 problems, the carb float needle should stop the flow before it floods into cylnder, so it may need a clean or replace. If it floods when engine not running, the fuel tap may need cleaning or a repair kit, as it should stop the flow when the engine stops
Apr 03, 2010 | 1996 kawasaki VN 1500 Vulcan Classic
Hard to start hot 1500 mean streak
the fuel is evaporating with the heat of the engine,hence hard to start untill its cooled down, check you fuel filter / pressure regulator and see if its holding fuel pressure..
Dec 06, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
96 ford explorer v8 wont start all the time
try replacing the fuel pump reley
they are a little bit funny in fords
i had a ford 1 time thet ran fine for hours in the driveway but go 2 blocks and the truck would die dam reley took me 2 monthes to diagnose once i did i had a great vechiale untill a dui hit me broad side
Jul 25, 2009 | 1996 Ford Explorer
Runs for 20 seconds then dies
Check the fuel pump, make sure it is putting out proper pressure if not then change the fuel pump
May 28, 2009 | 1994 Jeep Grand Cherokee
95 Bonneville won't start when hot
Yes I know, but If you hold the accelerator pedal to the floor on a fuel injected car, the Throttle position sensor will tell the computer to enter clear flood mode. Then the computer will shut off the fuel injectors while you have the pedal to the floor. If it is flooded, you should be able to get it started in clear flood.
Mar 09, 2009 | 1995 Pontiac Bonneville
96 Astro Fuel Pump Question?? no start/Flooding
With the upper plenum removed and spark disabled turn on the key and allow the fuel pump to prime while watching the fuel lines from the back of the intake to the injector. I suspect you lines are leaking. Have seen this before. ALOT.
Nov 24, 2008 | 1996 Chevrolet Astro
Lands Phones Logo
49 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
