Question about CyberLink PowerDirector 3 for PC
Error code when i burn to disc it gets to 96% then says error code c0040004 This is in Powerdirector version 7
  • 3 more comments
  • jec1 Feb 16, 2009
    Same exact error message at same exact completion process, 96%. Using WinXP w/SP3 and latest updates.
  • Anonymous Feb 16, 2009
    Exactly the same error, also in Power Director 7
  • luisalbertop Feb 23, 2009
    Same error, Power Director , ending creation of video in DVD or Hard Disk
  • Anonymous Mar 21, 2009
    When PowerDirector almost fnished burning (95%), it sais "Failed! ErrorĀ c0040004"... Tried two times, two times same error at same point.
  • Anonymous Apr 20, 2009
    Same error message. Although on my one computer it only brings up the burning menu, and then doesn't start burning at all. My other PC starts burning up till 96% and then springs the same error code. Running on XP home SP3.
3 Suggested Answers
  • 403 Answers
SOURCE: PowerDirector 7
Try this link at CyberLink.
http://forum.cyberlink.com/forum/posts/list/15/1823.page
Maybe uninstall and try a new version. Try this link for that.
http://extratorrent.com/torrent/1559723/Cyber+Link+PowerDVD+8+Ultra+1830.50+Build+%2B+Updated+Keygen.html
Hope this helps. Let me know how it goes.
JimmyC
Posted on Sep 27, 2009
SOURCE: powerdirector 8 created dvds will not play
when i play my dvd's video it not work video can't display
Posted on Feb 03, 2010
Powerdirector 10 script installer error cannot create file??
Try to install on a different PC. Also, ensure you have the latest Microsoft updates and service pack. Contact KWorld for support and possible newer compatable software download from their website.
Nov 16, 2013 | KWorld Xpert DVD Maker USB 2.0...
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Burning unsuccessful track reservation not complete
YOU HAVE TO FORMAT YOUR DISK .. BEFORE BURNING OR DOWNLODING ANYTHING TO IT.... FORMAT YOUR DISK WITH THE PARTIONS ... IT A MUST... ITS IN YOUR COMPUTER PROGRAM... WHEN YOU PUT YOUR DISK .. GO TO PROGRAM AND LOOK FOR FORMAT DISK.. AFTER YOUR COMPUTERFINISH FORMATING YOUR DISK .. ITS READY TO BURN IT....
Sep 25, 2012 | CyberLink PowerDirector 9 Ultra64
Powerdirector 8 created dvds will not play
Feb 02, 2010 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
PowerDirector 7
JimmyC
Sep 27, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Need Vista compatible CD ROM
Hello there,
Unfortunately, JVC is not offering the latest version of their Powerdirector on the website. You can however have the option to purchase it. This version already fully support Vista and Windows 7. Please see link below:
http://www.cyberlink.com/products/powerdirector/requirements_en_US.html
Aug 08, 2009 | JVC Everio GZ-MC100 Memory Card Camcorder
Burning of DVD from Power Director V7
LOOK IN TOOLS AND SETTINGS OR HELP AND FIND THE UPDATE BUTTON AND UPDATE THE SOFTWARE. PLUS YOU ARE RIGHT THAT IT MAY BE PROBLEM USING EXTERNAL DRIVE.(IS IT USB 1.0?)..COPY YOUR FILE TO A TEMPORARY FOLDER ON YOUR DESKTOP AND BROWSE TO THAT FOLDER WITH POWER DIRECTOR.
May 28, 2009 | CyberLink POWERDIRECTOR 7 VLICDELUXE for...
PowerDirector 6- disk type mismatch error???
same thing happened 2 me but with power director 7.0 i need help 2. i worked a total of 5 hours on a movie and i can't burn it. somebody help us!!
May 26, 2008 | CyberLink SW- DVD Software Power DVD...
CyberLink PowerDirector 3 for PC Logo
431 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
