Iron won't heat up - Audio Players & Recorders
  • 304 Answers
If You open the Iron. with it unplugged of coarse, You will find a small cylindrical component in the simple circuit called a thermal cutoff. It is a safety device to kill the power to the device in the event of overheating avoiding the possibility of fire. An iron only has 3 parts a heating element, a thermostat/switch, and a thermal cutoff.
The thermal cutoff will be along the metal surface on the inside of the iron. In every case I have ever seen replacing thing thermal cutoff switch has repaired this problem. Hope this helps out with your problem. Never Bypass this cutoff as it is a safety device
George
Posted on Jul 20, 2008
  • George Kohler
    George Kohler Jul 21, 2008
    I'm glad you found my solution Helpful. In return I ask you
    to go to my profile and read and rate some of my other solutions. I put
    25 years of experience, 3 years of Deans list University Dual Degree's
    in Business Management/Computer Science, 2 Years of Tech School for
    Industrial 3 Phase Wiring, Founder of three major businesses and 1 hour of research into nearly every
    post barring the short and obvious solutions. As my post helped save you, I ask
    you to help some others by weeding out some of the garbage that winds
    up slipping though here. Please take a few minute and go to my profile and go through
    my
    unrated posts and rate them objectively and fairly and you can help
    some others the way I helped you. Check out some of the comments on my
    online chats. You will see I'm constant and Your case was not just a
    fluke.
    Thanks,
    George
    Master:
  • 726 Answers
Well its had it chuck it out
Posted on Jul 18, 2008
My rowenta Dw9280 steam iron won,t heat up.
Failure of heating element, control, or both
Mar 14, 2018 | Rowenta Irons
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
Singer 7467 wheel won't spin, unless little bit if I do manualy by hand...
do this
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.2_1_2013_6_01_09_pm.jpg
Jan 31, 2013 | Singer 7467S - Confidence Sewing Machine
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My Iron will not turn on! It hasn't seemed to heat up right lately anyway,but now it won't heat up at all.
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Jul 29, 2011 | Rowenta Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
189 people viewed this question
 Grubhead
Grubhead
