Question about Fisher and Paykel Refrigerators
We have a fisher and paykel fridge and freezer. The freezer section is at the bottom and it has started leaking around the bottom and I've noticed the bottom of the freezer becomes very icy very quickly. It is meant to not need defrosting but I only got rid of the ice 6 hours ago and it is already back. Could it be the seals?
  • 1,462 Answers
Not the seals. the drain is blocked. take the rear panel off inside the freezer and yoy will probably see an ice build up at the bottom. melt off with a hairdryer and follow up with hot water till water flows away freely. if you have ice build up all over the pipework, then you have a defrost system fault and get back to me
Posted on Jul 18, 2008
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Fisher paykel e224b fridge not cooling. everything working fine but fridge was originally pulled apart before i looked at it, need to know which thermistor is which (black and white ones in the freezer...
Kitchen Laundry Appliances Fisher Paykel US
Are you sure that is the part number. I went to the above link and could find nothing with a part number of E224B. Please look on your unit and verify there is no other numbers. If you find additional information please post it and we can attempt to help.
Semper Fi,
Feb 01, 2018 | Fisher and Paykel Active Smart E522B...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
537 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
