Question about Samsung Televison & Video
I have a samsung LA23R51B LCD TV. For the first 5 to 15 minutes after startup I am unable to obtain a high definition picture. The picture is badly broken up and accompanied by "No Video Signal " constantly appearing. Then gradually the picture clears and normal HD transmission commences and does so until I switch the unit off, and the whole things starts allover again . I have a DGTEC DG-T80SD set top box coupled to the TV. I would be grateful for an opinion on my problem. With thanks, Kevin.
  • 1694 Answers
SOURCE: Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Posted on Sep 29, 2007
SOURCE: Magnavox Projection DLP HDTV
I replaced my lamp yesterday 3/26/08 and still have the same problem. I kept turning it on / off before I replaced the lamp. 10 or so tries and it would stay on. I believe this eventually burnt out my lamp. Fans are clean/ new lamp, same problem. Another forum I read mentioned a firmware upgrade? Any advice.
Posted on Mar 27, 2008
  • 1689 Answers
SOURCE: no audio
I will try to explain this clearly.
Make sure that there is sound leaving from the connections on the top box.
Check that the audio cables are connected to the associated audio input for the video at the rear of the set. Make sure that there are no other shared inputs for the same input. With shared inputs, only one can be the default reference for input.
Check the menus in both the top box and the TV set to make sure that all setups are correctly done.
Jerry G.
Posted on Apr 14, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
  • 128 Answers
SOURCE: Sound only works with HD, not SD
Check the setup menus of the Insignia TV, as most sets have an advanced setting hidden deep in the setup menu to use the HDMI cable for sound - OR- use component RCA inputs for sound. My Philips TV has this.
It's odd that this only shows up for SD content...I would see if there is a firmware update available for that from the manufacturer. The one thing that you see lots of firmware fixes for are HDMI issues.
Posted on Oct 16, 2009
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
Why won't my Samsung LCD tv boot properly at startup
Hi Tom,
This is becoming a theme with Samsung TV's, Samsung have extended warranty cover for some customers with this problem, have a look at this post for more info and the link to Samsung:
have 60 Samsung led tv Sound keeps cutting out all night for 3 5 seconds...
Feb 13, 2016 | Samsung 9000 Series UN65F9000AF 65" 4K LED...
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung model no. LN 32A33OJ1D code. LN32A33OJ1DXZA wont turn on for nothing and someone try to charge me $500.00 to fix it need help !!
If I am corrct, It may just need a set of caps in the power supply, about $15 worth and may be 45 minutes of time,
see pictures here;
Sounds like someone is ripping you off or never works on repairing TV before, jhe ust gives you high estimate and charge you alot just for the estimate alone. That kind of repair shop gives all repair shops bad name.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Samsung LN32A330 32 in. LCD TV
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Nov 08, 2007 | Televison & Video
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Televison & Video Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
