Question about RIM BlackBerry Pearl 8100
97 lincoln mark viii lower control arm.....
I am trying to replace my own lower control arms. Do i need to deflate the front air bags in order to do this. and how do i do it.
    Problem Solver:
  • 6 Answers
I am not sure if you have to deflate the air bags, but i'd assume so. First, turn off your air ride switch from inside your trunk. Then lift the front of the car in the air, make sure to lift from the frame. Next remove the wheels. To deflate the air bag here's what you do. First remove the solenoid retaining clip, located at the top of the solenoid. (It will come off with a flat head screw driver). Next turn the solenoid until it stops, (this can be counterclockwise, or clockwise depending on which side of the car your on). Once that is done, pull down on the solenoid until it stops. You should hear hissing as the air bag deflates. You can put the solenoid back in now, however i would leave it like that until you are finished replacing the lower control arm. Once your finished with the control arm, push up on the solenoid, and twist back into original position. Reinstall the retaining clip, and move to the other side of car. Hope this helps
Posted on Sep 05, 2009
I have 97 mark viii n I c that everytime I get out the front end is always on the ground but it do rise up when I start it
Your mark viii has a air ride system. and as you drive, it has a pump under the hood. well over night it leaks down. then when you crank the engine .this pump will come on and air up the air ride system.kind of like a tire.But if just the front goes down ,Then you have a leak at the 2 front bags or lines, or connections. to find the leak try some soap in a spray bottle. after the bags are fully aired up and the engine off.some Lincolns leak worse the way they sit. it could leaking in a few places,that is what the soap is for.you can buy every part for that system from, Air Suspensions out of Orlando FLA 1-800-251-8993.plus diagrams
Oct 02, 2011 | 1997 Lincoln Mark VIII
I have a 1994 lincoln mark viii. the front air bags keep deflating and sometimes stay up. every now and then you can hear the pump and it makes weird noises and will not pump at all. its like i am driving...
Unfortunately, it sounds like the air compressor for your air ride system is not working. But before you replace make sure that the height sensors haven't gone out which would bleed deflate the bags. SunCore Industries has about the best prices for the air compressor, dryer and air struts and bags.
Changing them is no picnic, but there is plenty of information at SunCore on step by step instructions to do it.
I have a 96 Mark VIII and have had to replace the rear bags and two height sensors and the air compressor so far, but when they work as designed they are a very smooth ride. A friend went with the replacement non-air ride and there is a big difference in how it rides.
Sep 10, 2011 | 1994 Lincoln Continental
My rear air bags are too high and will not deflate. The sensor is connectod ok on the rear arm. How can I deflate it manually. It is on a 1994 mark VIII
you can remove the rear lines at the air bags to deflate. most likely the problem is the air suspension control module is not turning the venting valve on to release the air from the bags.
Aug 10, 2011 | Lincoln Mark VIII Cars & Trucks
What is the common issue regarding the air bags for the suspension?
there is a ride hieght sensor on rear lower control arms creck for damage and connection.over load rear suspention,4/5 people on back bumper with key on see if pumps up.also check fuses.try jumping compress to test compressor.worst case replace struts and use coil springs,eliminating air ride issues.
Feb 18, 2011 | 1997 Lincoln Mark VIII
I have a 1993 lincoln mark viii trying to manually add air to rear air bags i have installed the hose kit but they wont accept air how to fix
Don't bother. Check with srtutmasters or other alternatives. If the car was made in 93, all bags will be leaking and eventually the compressor cant keep up and fails. even your local lincoln dealer will not be able to diagnose the problems with their "computers." You can get lifetime struts and spring, in your case just springs for the rear, lincoln shocks still work. Put new struts and springs in the front. The only difference is the car will not lower itself at 60 mph or higher. the ride is the same.
Jan 26, 2010 | 1998 Lincoln Mark VIII
There is a knocking coming from underneath the left side. i've replaced upper control arms and ball joints and lower balljoints, inner and outer tierods and swaybar links and still didn't solve problem
check to make sure the strut is good and tight up top. There's 3 nuts there. and i'm assuming it's the original air suspension. if it's been converted could a bad strut itself.
Jan 20, 2010 | 1995 Lincoln Mark VIII
My licoln navigator front suspension is not working..stays deflated
First, you should have a warning light telling you it is not working. There is a switch for the air suspension underneath the glovebox-right hand side or in the rear hatch area on the left panel..make sure it's on. If all 4 air bags are deflated it could mean the air pump or actuator is malfunctioning.
Dec 13, 2009 | 2004 Lincoln Navigator
2001 Lincoln Continental gas door push button broken
Hi Mike,
I used to work at an auto salvage yard. Great inexpensive source for items like that.
Pull yours first so you know what tools you'll need. This way you won't be lugging a heavy tool bag, you can travel light while you look around.
Best regards
Mike
Aug 17, 2009 | 1996 Lincoln Mark VIII
No heater or air conditioning is it the heater control valve or possibly climate control?
I had the same problem. It turned out that the small gray plastic lever arm that opens the mixer door was broken. The big problem with this is that to access this arm and mixer door, you have to remove the dash. You can feel and see the lever by dropping the glove compartment all the way and reaching to the front and left. It was a pain to replace, but well worth it.....
Sep 18, 2008 | 1998 Lincoln Mark VIII
Air suspension
recently had the same problem looks like a common prob among lincoln 8 i went to a junk yard picked up a front right air bag strut assembaly 25 dollars 3 12mm bolts and 1 7/8 big bolt on bottom can be removed and put back on in one days time with no complications dont forget to cut all hoses and wires back far enough to maybe use again if you have to u need the check valve attached to the bag as well good luck seem to fix mine ( hole in the bag)
Aug 14, 2008 | 1994 Lincoln Mark VIII
RIM BlackBerry  Pearl  8100 Logo
83 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
