If it was the key or the theft deterrent system it would have a light on dash with a key symbol I would check the relays in the power dist box for crank and ign make sure there good and if you have another key try it also and it's possible the receiver for tds is bad is is in the column and is around the ign switch
SOURCE: 2005 Dodge Magnum w/out hemi stalling
I have a 2005 Magnum and was also having this problem. Stalled out a few times and continued to idle rough and feel like it was going to die when I would slow down. At times it would feel like I would get a hesitation and then a surge. Engine light would go on for a day or so, then go out for a few days. First time I took it in, the dealership told me that it was a broken seal (I don't know where), but they replaced it and it continued to happen. The second time I took it to a mom & pop shop, and they told me that it was the oxygen sensor/altimeter, replaced it (only a $35 part), and I haven't had a problem since. That was 6 months ago. Hope this helps...
SOURCE: 1995 Chrysler Concorde
the alarm is activating when he locks it and for some reason the key or fob isnt deactivating it..check the disarm switches in the door
SOURCE: 2005 Dodge Magnum, after replacing battery,cd player won't work
My story Dealing with Dodge
I had a 1994 Dodge Ram. The Red Dodge Ram I had it malfunctioned and my brake became the throttle.
I had to put the truck in reverse then park. to stop, after it was out of control at 80 mph a hill slowed us down. Are you sure
its not electrical and the curse control is not giving you trouble?
Mine had multifunction switch was not working and the headlight switch burned up. I also found out that Audi had problem with the brake becoming the throttle
in the 1980s Daimler Chrysler and Audi were German made. I don't think
there is an easy answer. I hope you stay safe. Another man is having
strange trouble also. I'm sure there are many more people with trouble
with the vehicles. I wish Dodge would step up to the truth. and recall
their nightmares. I saw many of their 1996 Dodge trucks at their
dealers shop with all the electrical pulled out.
SOURCE: unable to locate the fuel filter on my 2005 dodge magnum 2.7 liter
It's located in your fuel tank.
cheers.
SOURCE: 2005 dodge magnum 3.5 liter engine. 10 deg start engine noise
these have a problem with the overhead cams, one or more of the bolts break which restricts the oil flow to the lifters.
