Question about LG Dryers
LG GAS DRYER DLGO332W
TUBLES BUT WILL NOT HEAT
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
You will have to check the thermistor as well as the rest of the sensor. Make sure the gas is off and the unit is unplugged befor you open the back of the unit. If the sensors test good than you may have a bad heating coil unit. All the parts can be tested for free at your local appliance parts supplier.
Posted on Nov 24, 2014
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: dryer tubles does everything like its supposed to
Hello there
Here is some things that could make the dryer not work properly meaning heat wise please click on the items listed in blue and go thru each of them this will help you troubleshoot this
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Apr 16, 2010
  • 121 Answers
SOURCE: I have an LG Gas dryer. Almost daily no heat is
Check your exhaust duct - the long tube that goes from the back of your dryer to the vent outside. It may be clogged with lint.
Posted on Oct 08, 2009
  • 105 Answers
SOURCE: My lg dlg7188rm gas dryer will not heat. the gas
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Posted on Feb 01, 2010
Testimonial: "great explanation. thanks,"
My lg dlg3744 gas dryer will only occasionally heat any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 14, 2011 | LG DLG7188 Gas Dryer
LG DRYER DLG0332W GAS
heatman101[[]
Aug 05, 2011 | LG DLE0332 Gas Dryer
LG Gas Dryer not heating up
heatman101
Mar 24, 2011 | LG DLG5932W Gas Dryer
Gas LG dryer not drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 07, 2010 | LG DLG5988 Gas Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
My LG dryer will not heat, the model number is DLGO332W. I cleaned the entire lint system, thinking it was blocked preventing ventalation and then preventing the heat element to kick on. Not the problem....
I would check the thermal fuses to see where they are open or not. They are located right on top of the heating element.
Technically you can disconnect the wires and short them together(Don't leave like that) just to see if they are bad. You always use a meter.
Dec 18, 2009 | Washing Machines
Unit tubles but does not heat?
Heating element most likely but if this is a newer model I would check all electrical connections.
Jun 09, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
199 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
