Question about Refrigerators
GSI-26 ice maker will not eject ice
The ice maker fills, freezes the water into ice and ejects the ice correctly MOST of the time. Intermittently, however, the eight ejected cubes of ice will freeze to the back of the ejector bar causing the ejector fingers to stop their motion in a vertical down position. The cube tray will refill and now the ejector fingers will be frozen into the center of the next batch of eight ice cubes. If the stuck condition is discovered before the ejector fingers are frozen into the next cubes, the problem is solved by breaking of the eight cubes that are frozen to the back of the ejector bar. The ejector bar and fingers rotate to the normal aft horizontal positon. Everything will then work normal for as much as 2/3s of a tray of ice cubes then the ejector bar will freeze again before the finger return to the correct postion. Any ideas for a solution?
  • 2 more comments
  • Anonymous Aug 24, 2008
    I have the same problem, whats the solution?
  • tiedt Sep 02, 2008
    same exact problem, would love a solution
  • philsdale Oct 18, 2008
    Same as above. The ejector freezes then gets stuck. What can be done??
  • Anonymous Oct 22, 2008
    Welcome to the sub-zero iced up ice makers club. I have the same problem. It does work some times and then freezes up at other times. It's always the two or thee cubes and ejectors closest to the water dispenser. Anyone got any ideas?
4 Suggested Answers
SOURCE: side by side Whirlpool with door reservoir for
Replace the ice maker electronic module in the ice maker head. The gear is stripped. This module controls the enitre process in making ice. Can be easily changed in about 5 minutes. If we can help further....
Eric Campion
Posted on Feb 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ice maker jammed. Ejector fingers in incorrect position.
The ice maker should make an attempt to get the fingers in the correct position on its own. If it doesn't then it probably is bad. I always that out the jammed ice cube with a hair dryer till the fingers move over to the harvest position. No need to remove the ice maker. Their is going to be a fouled ice cube on these newer ice makers from time to time.
Posted on Apr 06, 2010
  • 2006 Answers
SOURCE: The icemaker on the KSRB25f keeps jamming. The
Where you say occasionally, I would suspect a rough edge on your stripper arm or a ejector arm slightly out of alignment.
Posted on Jul 18, 2011
The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
Jun 14, 2008 | Frigidaire FRS23H5AS Side by Side...
My Maytag ice maker stopped working; ice on doors & draw; What do you think might be causing this?
As odd as this sounds, my Maytag MFX2570AEM stopped making ice. I could feel ice in the tray but it suddenly stopped ejecting or making more even when the bar was in the correct position.
I read many articles telling me the motor was dead, the gears for removing the ice from the tray needed to be replaced, etc. THEN, I read one person who responded that his issue was resolved with a HAIR DRYER. It turns out something about the unit had frozen due to water getting on it, etc.
Sure enough, after blowing a hair dryer into the ice maker for 5-7 minutes I replaced the ice maker drawer and in about a minute it ejected the ice and filled the trays with water again. It has been making ice ever since.
Jan 31, 2015 | Maytag Refrigerators
Ice cube ejector bar keeps freezing preventing ice from ejecting to tray
Replace your water valve part # WR57x10032, from what you have listed above you have a bleeding water valve allow water to enter the ice maker mold. The valve is not closing completely. This part show fix this issue for you.
Good Luck
Mar 30, 2014 | General Electric GE GSS25GFXWW (25.0 cu....
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
I have a Frigidaire Model# FRS26H5ASB9. The ice maker is a GSI-26. The ice maker water line freezes up and then the ice maker does not work. It goes thru the cycle and it sounds like it is filling but no...
The most likely reason for this happening is a defective Click Here=> 241734301 Triple Water Control Valve These valves are located on rear of refrigerator and near floor where the water supply enters your Refrigerator. CLICK HERE=> FRS26H5ASB9 USE AND CARE GUIDE
The valve location is listed on page 5 of the Use and Care Guide, If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) This problem is typical as a leaky faucet that drips even when the water valve is turned off. I will be here to answer any questions you may have, Thanks Sea Breeze
If helpful please rate this solution, Thank You
Jul 16, 2011 | Frigidaire FRS26H5AS Side by Side...
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | GE Refrigerators
Currently the water is leaking from the ice maker. there is ice build up in the control box its self, and its leaking from there. No sure how the water is getting in tot he control box itself so i'm...
You are right - it is filling up with too much water. If you remove the front panel of ice maker you will find a screw there that adjusts the length of time that the solenoid stays open to admit water. Turn it counter clockwise to reduce the time and amount of water entering the ice maker.
If you need new maker get them cheap on ebay. eBayeBay
Sep 08, 2017 | Frigidaire FRS23H7CS Side by Side...
Is the position off - or the icetray heater failed?
Just before ejection - there is a heater element that warms the ice for easy discharge.
Check that the heater is working.
Reply with the model # of the fridge for more exact help.
Thanks!!
Apr 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Aug 21, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
888 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
