Question about Insignia Pilot MP3 Player
Itunes compatible Will the Pilot work with Itunes?
You can drag the files from iTunes to the player in file and folder mode, as long as they're in the supported formats.
Posted on Jul 20, 2008
When iTunes 10.5.2 is started, PC running Vista 32 Bit, monitor screen resolution changes
Sounds like a compatibility issue. You want to ensure that iTunes is not set to run in compatibility mode. To check this please follow the steps listed below: Step 1. Exit out of iTunes.
Step 2. On the Windows Start Menu select Computer.
Step 3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit) users browse to C:\Program Files (x86)\iTunes.
Step 4. Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
Step 5. Next select the Compatibility tab.
Step 6. Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
Dec 30, 2011 | Computers & Internet
After installing itunes when i try to run it windows gived me a dep error tried to change settings in dep but that doesnt work
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Dec 30, 2010 | Apple iTunes
I think I have correctly installed itunes on my new Windows 7 computer. When I try to load music from a cd, I get, "iTunes has stopped working. Windows can check online for a solution to the...
Dec 02, 2010 | Apple iTunes
What version of itunes is compatible with iPod nano 5th gen?
I have the same iPod and it works with any version, at least mine does. Try downloading it here itunes.com
that's where I went to get mine. And it worked. Hope this helped!
Apr 09, 2010 | Apple iPod nano 5th Generation
Itunes .exe has been set to run in compatibility mode for an older version of windows. i already tried to change version but cant find windows 7 version also turned off compatibility still no luck
Unfortunately, even though I'd turned off compatibility mode for iTunes (by right-clicking the iTunes icon, choosing Properties, clicking the Compatibility tab, and clearing the Compatibility mode checkbox), the program generated this irksome message every time I ran it:
Sigh. Stupid Windows. Or maybe stupid iTunes. Either way, compatibility mode was "off," but iTunes didn't think so.
Fortunately, I finally found a solution:
3. Navigate to this Registry location: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
Dec 16, 2009 | Apple iPod MA446LL/A MP3 Player
Itunes and pilot
The whole point of the Pilot is to avoid the tether to iTunes. I'm not sure you can really sync with iTunes but you can easily copy your music to the player. The path in Windows to the iTunes music library is usually under the My Music directory under iTunes\iTunes Music. I created a folder on the Pilot named iTunes Music and copied all the folders under the iTunes Music folder on my laptop to the Pilot folder. Playlists are also supported but if you create the playlist file in iTunes you may need to convert it to m3u format. You will also want to go into the settings and set the USB mode to File & Folder.
Jun 02, 2008 | Insignia Pilot MP3 Player
Itunes and insignia pilot
All of your Itunes music is held in a specific target folder. In the folder options (somewhere on Itunes :P) is the location of this folder. These are simple files that can be put on a cd, copied, or put into another folder to be put on your insignia player. Hope this helps!
Converting from Palm Pilot TX to iTunes
There is probably a compatibility issue between the TX, Pocket Copy, and Iphone. TX is pretty picky about what can be used to transfter information. They only recommend Outlook and the one that is included on the TX CD.
TX and IPhones are different systems as well. You could try to get the files exported from the TX into a CSV and see if you can import the files into Iphone that way, if it will import them.
Good luck on that one.
May 06, 2008 | Palm TX Handheld
Transferring Itunes to MyMusic
I believe that Itunes is only compatible with the Ipods.........however, there is a workaround. You need to burn the itunes downloads to a CD, then rip the CD back into an MP3 compatible music program. I'm attempting this as I type.........I burned the itunes songs onto a cd, and then ripped them into Yahoo Jukebox. One sec, and I'll let you know if it worked.
Yay.........it worked! Good luck. :)
Dec 27, 2007 | RCA TH1101 MP3 Player
Cant Install Or Replay Playlists NS-DA2G
I called insignia. An extremely rude cust. service rep. told me that the player doesn't work with itunes playlists and is ONLY mac compat. as a storage device.
What a crap answer! I actually can get songs on the thing and they play, but playlists are a lost cause.
Sometimes technology sucks.......
Nov 07, 2007 | Insignia NS-DV2G MP3 Player
Insignia Pilot MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
tk007
Level 1 Expert
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
