Question about Intel DQ965GF Motherboard
Picky Intel motherboard?
Greetings, peoples.
I got a weird problem with a motherboard: It will not recognize my CD-ROM drive connected to its one IDE channel, and my SATA drive comes up as 'having a problem'. The motherboard is an Intel DQ965GF, running a 2.4GB, Core2 Duo processor. The CD-ROM in question is a Toshiba XM-5702B.
  • nevanlanos Jul 19, 2008
    I am very sure of the IDE connection. However, problem is now different: it will recognize my hard drive, but will not let it boot, and my CD-ROM still acts as if unrecognized.
    Will try updating the BIOS, see if that has any effect.
  • 84 Answers
Possitive the IDE is on snuggly ?
New bios came out last month for this mobo
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=2372&OSFullname=OS+Independent&strOSs=38
Posted on Jul 19, 2008
How do you connect IDE device to GA-Z87X-UD4H
This particular motherboard does not provide IDE connections for external devices. The safest option would be to use an IDE expansion card that will plug into the PCI bus and provide normal IDE connections for your devices.
A quick search to google for "ide expansion card" will provide many good results.
May 11, 2014 | Gigabyte GA-Z87X-UD4H rev. 1.0 Socket H3...
My computer can't see any IDE drives in setup i
i see do you use only 1 ide cable?if you only have 1 ide cable and it is connected to to of your drive...you must put one of your drive's jamper to slave....it must be the cd rom drive...hope it works...
Dec 09, 2010 | Dell OPTIPLEX GX60 Motherboard
I need to know what order to put the wires from the mother Bord to the floppy drive to the cd Rom\burner to the hard drives
The floppy drive has it own data cable and does not connect to the same cable as the hard drive and CD ROM/R-W drive.
If the hard drive and CD drive are IDE devices, then the hard drive should be the connected to the connector at the end of the IDE cable and the jumper on the hard drive set to Master. The CD drive should be connected to the middle connector and its jumper set to Slave. The other end connector should be connected to the Primary IDE connector on the motherboard.
Nov 11, 2010 | Intel Computers & Internet
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
New gigabyte EP45-UD3P mb intel q9400 dvd drive won't burn dvd
many people when doing bios-hardware updates. leave optical drives connected. this can have adverse effects on connected items. the only 2 suggestions i have for you are:-
**** uninstall and re-install the Drive first In device Manager****
1:) if the motherboard has 2 ide slots Primary/secondary. put the dvd writer on the secondary, or vice versa. and setup as a Master Drive. ( jumper block at rear )
2:) Go to lite-ons website. and see if there is a firmware available for that model of DVD Rom drive. and carefully re-flash the drive itsel.
Hope this guides you in the right Direction.
Mike @ compurepair.
Apr 01, 2009 | Intel Motherboard
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Dell Dimension 8200 turns off in BIOS
If the dianostic lights A & D are yellow an IDE bus failure has occurred. Reseat the IDE cables at the motherboard and drive(s). If this does not resolve the issue you may need to contact Dell for a motherboard repair or replacement.
Mar 13, 2009 | Computers & Internet
I just bought a refurbished netvista pent4 2.4g. from computer geeks. it has no O.S. or drivers
Dear Transtripper,
It shows that your IDE option is not enabled in the BIOS. So, enable the IDE Controller in your motherboard.
Thanks,
Sep 26, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Intel DQ965GF Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
