Question about Vizio L32 32 in. LCD HDTV
Vizio L23 HDTV 10A
I have had the unit for about 1.5 years, it has been shuuting down by itself for some time. Tonight sparks flew and it shut down.\, I assume permenently.
I have been getting little black rectangles on my screen that increase in number the longer the tv is on.  What can I do to stop this?
Posted on Jul 22, 2008
  • 6 Answers
Sounds like the power supply board blew. You can purchase a new one directly from Vance Baldwin. They are the only parts supplier for Vizio. http://www.vancebaldwin.com/
It's just plug and play. remove the old circuit board and replace with the new one. Not difficult and it should solve your problem for less than $100.
TV would shut off by itself and then several minutes later be able to be turned back on. A day later it shut off by itself, turned itself back on, shut its self off then a huge pop sound as purple and...
That tv is very old and it just reached its life expectancy. It could be repaired but it will cost you more than a brand new tv. Black Friday coming up and you will find a great deal.
Oct 29, 2013 | RCA HD52W59 HDTV Projection Television
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
My 32 inch Vizio HDTV keeps shutting itself off. I turn it on, the Vizio label comes on, and it immediately shuts down. My son was playing with the remote before this started, and the screen said input...
Reset the TV to its factory settings. For more details, refer its user manual. Unplug the TV from AC mains socket, and replug it after some time, say after 2 minutes or so.
May 11, 2012 | Televison & Video
Tv shuts off by itself
Let your unit cool down for 30 mins. Give a proper ventilation by keeping away all obstruction in the airway. Your unit has a heat sensor, when it reached the peak temperature allowed the unit will automatically shuts down.
If the symptom still there after giving a proper ventilation I've advice you to send it to repair shop because the problem might caused by out of regulation caused by faulty electrolytic capacitor and regulator IC on the power supply.
Have a nice day! Thanks for using fixya.
Jan 30, 2011 | Vizio L32 32 in. LCD HDTV
Tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Jul 19, 2010 | Vizio VX37L Television
My Vizio turns itself off on a certain channel (ch 17-1 Phila)
I have this same problem with channel 5-1 Los Angeles anyone have any advice?
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
I cant find cc button in my remote> my TV model is v032l HDTV 10A
Perhaps you have to actuate the CC function by using the menu structure within the TV itself?
Feb 27, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
No Power
It appears that the power supply is starting to fail. It is also possible that there is another board in the set that is over-loading the supply.
The nature of the fault indicates the strong possibility that there are some parts that have become thermo sensitive. This is not a reset problem going by your description. Unplugging the set, is allowing the boards to cool down, and therefore they will work for a while until the thermo sensitive parts heat up again.
Jerry G.
Mar 25, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
136 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
