I have an hp laptop and there are three power options. the one i have currently set and it is balanced between computer power and computer performance. the one i want is the one where the battery last longer and the computer performance is a little less. which one would be better and what is computer performance and will it slow down the internet.
    Novelist:
    Scholar:
  • 160 Answers
Set it up so when it's on AC power, nothing is shutdown. On battery, I set mine to shut down after 30 minutes of inactivity.
I never let power mgmt turn off the hard drive in either mode. It doesn't save much when on battery, and usually causes problems with certain programs.
Internet access wouldn't be affected by these settings.
Another power setting that should not be on, is found under
Control Panel/System/Device Manager/Network Cards.
Right click on the network cards, go to Properties/Power Management.
Clear the boxes that allow the computer to turn off the card. Another setting that's more trouble than it's worth.
Posted on Jul 18, 2008
Laptop will not charge
Step 1:
Windows 7 Laptop Battery not charging b> Careful management of battery charging and power consumption settings on your laptop computer is essential if you spend a lot of time away from home or the office. To stop your Microsoft Windows 7 laptop from running out of juice at a critical moment, you can change the battery and power settings for the device. Select the battery meter icon from the desktop toolbar to change the laptop's power plan.
Click the battery meter icon in the notification area on the right-hand side of the computer's desktop taskbar. This launches the battery and power plan options dialog box. Find the battery status display at the top of the dialog box. This shows the remaining charge in the laptop battery, and indicates if the battery is currently plugged into a power supply and charging. Click the check-box beside the power plan option that best matches your current activities. Select "High Performance" if the laptop is connected to an external power supply and the battery is charging. Choose "Balanced" if you don't need to save power and you want Windows 7 to optimize the laptop's power settings. Select "Power Saver" if you need to run the laptop on only battery power for as long as possible. Click anywhere on the desktop screen to exit the battery and power plan options dialog box.
Feb 06, 2013 | Samsung RF511 15.6 inch Laptop - Black...
The fan works on battery but not on power
Sounds like your power management settings have been played around with. See if you can reset them.
Go to Control Panel
Click Power Options
You'll now see you have one selected like "High Performance" or "Balanced".
Click on "change plan settings" next to the one that is selected
click on "Restore default settings for this plan"
Dec 21, 2012 | HP Computers & Internet
I have HP Compaq 6910p and having issue with its battery/changer as laptop screen become bright on battery and uses more battery then normal.
Right click the battery icon next to the clock on your taskbar. Select "Power Options" At the bottom, there is a slider for screen brightness. Slide it left to dim, slide right for brighter.
If you want your laptop to automatically adjust the brightness based on whether it's plugged in or not, click "Change plan settings" next to the currently selected power plan (usually Balanced).
On the new screen, there are 2 sliders. I would recommend setting the Plugged In slider to max and the On Battery slider to about 1/2 to begin with. Then adjust them to personal preference.
May 11, 2011 | Computers & Internet
My mini keep going into hyperination
Click Start>Control Panel>(in the drop down select icons) Power> In power select a power option such as balanced or edit the one you currently have. You can set your netbook to never go into hibernation. There are different settings for plugged in and battery power.
Mar 09, 2011 | HP Mini 1000 Netbook
I don't now how control battery level in my asus eee pc 900.
  • Click on the "Start" button.
  • Click on "Control Panel" in the right-hand task pane.
  • Click on "System and Security," located on the upper left-hand corner of the screen.
  • Click on "Power Options."
  • Click on your desired power plan. Windows has three default power plans: "Balanced," "Power Saver" and "High Performance."
  • Click "Change Plan Settings."
  • Adjust the brightness and performance settings that you want your computer to use while operating under battery power.
  • Click "OK" to confirm these changes.
  • or you can use battery softwares for controlling battery level.
    Good Luck
    Feb 20, 2011 | Computers & Internet
    I have an Hp Probook and when the charger is out the screen darkens. I have seen this before on my friends computers and they are able to brighten theirs. How do I do this with mine?
    it's in control panel power options, change your current power scheme settings , you should have a brightness slider which will make it brighter on battery power, good luck
    Sep 05, 2010 | Computers & Internet
    The pc isnot bright and its abit dull
    Is this a Desktop, or a Laptop. If it is a laptop, you should click the Battery Icon on the lower left corner of the screen. Once you click that, there should be a few options. They are as follows:
    Balanced;
    Power Saver;
    High Performance.
    The Balanced and Power Saver options reduce the brightness of the LCD Screen, as well as it conserves energy while running programs and the like. On "Power Saver", your computer may work slower.
    If you want your screen brighter, you can select "High Performance". Also, there is an option to personalize each of the three settings. Simply look below the three options where it displays three blue worded links. Click the one that says "More Power Options". This will take you to another page that displays the three settings and below each setting is an option to Change Plan Settings. Once you click "change plan settings", you can choose precisely how bright you want the screen to be for each setting.
    Once you personalize the three settings, you are free to go. Whenever you want to dim the screen you may go back to the battery icon and simply choose between the three modes. Hope this is clear enough. Good Luck! :)
    Aug 09, 2010 | Computers & Internet
    Screen is too dull when not plugged into ac
    Hi
    Yes you can
    If you look on your keyboard there will be a fn key and if you look at the other keys (generally on the up and down arrow) you will see 2 symbols which looks like the sun they increase and decrease the brightness
    Hold down the Fn key and press one of the keys if the screen brightness decreases press the other one
    Please can i ask that you leave feedback and vote if this has been useful
    Feb 10, 2010 | Samsung V25 XVC 2800 Notebook
    My hp dv1000 keep switching off even when i don`t run any programs ..
    Its a problem with the mother board , u need to replace a chip that handles electric current fluctuations.
    Go to the service center or dealer for the problem
    Jul 09, 2009 | HP Pavilion dv1000 Notebook
    Power saving doesent activate after unplugging from the power supply.
    go into the control panel, choose power saving option...Change your settings there to the desired time. Change the profile from performance to "balanced"
    Mar 20, 2009 | HP Compaq 8510w Mobile Notebook
    Computers & Internet Logo
    27 people viewed this question
    David Payne
    David Payne
