Question about Microsoft Windows XP Home Edition
How we will repair the hard disk
I want to check the boot sector of the hard drive
    Novelist:
    Scholar:
  • 160 Answers
Your antivirus program should be checking the boot sector for viruses. If it doesn't find any, and your machine boots fine, there's nothing else you need to do to the boot sector. The boot sector is also called the MBR - master boot record.
If there's something else you're trying to check it for, tell me what you're looking for.
Posted on Jul 18, 2008
Can I fix my Seagate hard drive to bootable?
Hi, two things to try.
1. If you have the Win7 cd/dvd, go here and read:
http://www.bleepingcomputer.com/tutorials/start-the-windows-7-recovery-environment/
But I'm thinking that you have a few bad sectors in the HD's boot area (educed from your tzak.tzak description - which is head seek (bang) trying to find the boot sectors). Which I'm not sure that Win7 recovery can cope with. But check out this link and read/follow links:
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/how-to-fix-the-boot-sector-of-windows-7/deb6ad12-a6b1-46fc-9786-240f66f9143e
And this link (better?):
https://answers.microsoft.com/en-us/windows/forum/windows_7-system/restoring-windows-7s-master-boot-sector-to/435f7bf7-9d5b-4741-9746-945ff06e6251
or
2. Go here and get SystemRescueCd:
http://www.sysresccd.org/SystemRescueCd_Homepage
It contains many tools for the repair of malfed systems.
You will want to use this tool: TestDisk
TestDisk[4]
Popular disk recovery software. Recovers lost partitions and repairs unbootable systems by repairing boot sectors. It can also be used to recover deleted files from FAT, NTFS and ext2 filesystems. File system recovery is supported for reiserfs, ntfs, fat32, ext2/3 and many others.
In closing, I would get a new HD, maybe a SSD? to replace your original hard drive (It may be failing, or it took a hard knock while in the boot phase, causing head-bang in the boot sector - not good). Make the new drive your master and use the old one for misc. data that you have originals of, i.e. music cd's, dvd movies, programs off-loaded from Tivo/DVR, etc.
Hope this at least gets you going in the right direction...
Oct 25, 2014 | Seagate BARRACUDA Computers & Internet
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
What do i do if hard drive boot sector is lost?
What do you mean lost? Deleted? your machine will not boot without this without the disk... reinstall it with the disk that came with your computer by booting from CD and repair the hard drive boot sector.
Jan 18, 2014 | Acer Computers & Internet
How to recover my seagate extenal hard drive ST903204EXA101-RK for free
A lot depends on what is wrong with your hard drive but assuming that it will still power up and will connect to allow data access, then I would recommend downloading a copy of Hiren's Boot CD, burning this to a blank CD, then booting the computer with the drive attached from this CD....On the Hiren's initial boot menu, select Dos Programs, then in the next menu, select option 6. Hard Disk Tools, then on the next menu, select option 1. HDAT2 which will allow you to Test and Repair Bad Sectors on the problem disk....Ensure that you select the correct drive from the Device List when shown - look at the Capacity to help doing so....Run the Drive Level Tests Menu to choose to Check and Repair bad sectors, then leave this to run - it will take some time to complete depending on both the size of disk and the number of problems found - the computer will give a BEEP sound for each error found!...If there are too many bad sectors that cannot be repaired, then time to use some of the other tools on the Hiren's Boot CD to recover what data you can from the failing drive.....Download Hiren's Boot CD from http://www.hirensbootcd.org/
Oct 25, 2011 | Seagate (ST903204EXA101RK) 320 GB Hard...
My operating system is corrupted by a virus i tried to slave my hard drive but i can only see my hard drive in bios and i cannot see it in my local disk drive and im hearing clicking sound inside my hard...
Try to boot from your OS cd or recovery disc. Run the disk check software and see if your hard disk is mechanically ok or it crashed. If your hard disk is mechanically functional then run virus check on your hard disk. This will clean all the virus infections. And you will be alright hopefully.
If your hard disk's boot sector is damaged you may want to format the hard disk and place the boot sector in another portion of hard drive.
Nov 07, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Hard disk failure
Go to www.gillware.com They can get files off damaged hard drives. If they can't recover your data, you don't pay anything. When you fill the form out, check "I was referred by an affiliate." And enter code 10869.
Aug 08, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Microsoft Windows XP Home Edition Logo
71 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
