I have a gateway computer, i have a lan provider and i called him and he set the linksys router model #WRT310N on my computer and my computer has now crashed i think....the error message reads: A problem has been detected windows has been shut down to prevent damage to your computer. If this is the 1st time you've seen this stop error scree and restart your computer If this screen appears again follow these steps. Check to make sure any new hardware or software is properly installed. If this is a new installation ask hardware or software manufacturer for any windows update. My screen then went blank...... I need help restoring it, can you help me??
    Novelist:
    Scholar:
  • 160 Answers
Disconnect the router and reboot. If the problem remains, it may not have anything to do with the router.
The router should have been set up with a cable from the modem to the WAN port, and a cable from one of the router's ethernet ports to your computer's ethernet port.
If you're going wireless, the same should apply, without the cable from your machine to the router.
Posted on Jul 18, 2008
    Problem Solver:
  • 42 Answers
Request resote / restore fm backup for the sys to any old time. and check any new software is installed, and also check the sys for viruses.
    Brigadier General:
  • 6,966 Answers
Hi again,
For some unknown reason(s) the Live Session/Chat was terminated.
With your indulgence, I would be posting here.
Cheers.
  • Louie  Role
    Louie Role Jul 18, 2008
    With or without the WRT310N, the Gateway computer should run without the error/crashing.
    Pls try running in Safe Mode (F8) and see if you can run your antivrus scanner. Thereafter, try again in normal mode, if that doesnt work yet, pls check/clean you memory (inside the PC). Might as well do the other add-on cards present. Try again, if still a no-go, try to do a system restore in Safe Mode.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
WRT310N
Hello I found the following info about the default settings on your router (you can reset your settings to the default ones by pressing the reset button on your router or the back of your router device):
Link is: http://pcsupport.about.com/od/linksys-default-passwords/a/wrt310n-default-password.htm
WRT310N Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Jan 28, 2012 | Linksys WRT Computers & Internet
Driver Linksys WRT310N Wireless Router
driver download link : has all the instructions you need. Should fix most problems.
1 direct link :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-Router-Upgrade-Firmware-1-255/
2 scanner :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-WRT310N-Wireless-N-Gigabit-Router-Firmware-Update-1-0-07/
May 10, 2011 | Computers & Internet
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Let me know if you need further assistance. Thanks for using FixYa.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
I can't get to stepG in setup of a Model WRT310N
Linksys has wonderful customer support. Call 1-800-326-7114 and they will have you up and running in minutes. I have the same router and have called a few times and was pleasantly surprised.
Dec 09, 2009 | Linksys Wireless-G WRT54G Router
Used to be able to connect using WRT310N
You should call Linksys tech support now. The router needs to be configured manually. The tech that you hired maybe not familiar on how to configure the Linksys router.
Jun 25, 2009 | Computers & Internet
Linksys wireless router
download the manual from linksys to start with. find out what the local ip-address is. normally it is http://192.168.1.1 Go to start/accessories/dosprompt and type: ipconfig enter read the number behind: standard gateway. that is the ip address. follow instructions.
Feb 23, 2009 | Computers & Internet
Networking my two computers
Are you trying to get both PCs to access the Internet or are you trying to have one PC access the other?
Aug 29, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Cannot get Internet connection with my new Linksys WRT310N wireless router
Power cycle modem and router. Check if getting wan ip address on router. I yes. Enter static DNS on router or on computer
Aug 19, 2008 | Linksys Computers & Internet
Gateway to gateway tunneling vpn
can you provide more information:
- WAN IP addresses of both routers
- LAN IP of both routers.
- name of ISP for both
i can provide a solution if i will know these info
Nov 16, 2007 | Linksys RV042 VPN Router
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
