Computer is not starting. beep sound - Computers & Internet
  • 6 Answers
•Remove the Side Panel from your CPU Case gaining acces to your Motherboard
•Remove the RAM Card from the Slot
•Just brush the golden colour parts at the end of the card slowly with your nails or use a Good Quality Eraser.
•Also Check if the power plugs are connected to the MotherBoard,Hard Disk and the Optical Drive are connected properly.
After doing all the above,your PC should be working properly.
If you still find it not working , Ring A Local Computer Technician and ask him to chk your PC.
Posted on Jul 18, 2008
Computer does not start...long beeps heard from the unit
removethe RAM strip then insert it again or change the slot
Aug 25, 2014 | Computers & Internet
There's a beeping sound during startup
Thank you for posting here in
The beeping sound is not a problem. Most computers produce a beeping sound when you start your computer up.
Thank you,
Jan 23, 2013 | Computers & Internet
Intel 31 3 beep sound solve
3 Beeps usually means a memory issue. If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Jun 02, 2012 | Intel DG31PR Motherboard
There is a beeping sound when starting up the computer
Beeping sound occurs due to problem in hardware.
Here is the complete list of beep codes:
Read it and identify the problem.
Use a system utility tool like RegInOut to fix computer corrupt registry and windows files.
Jan 05, 2012 | Acer Computers & Internet
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
My computer always beep. when i am printing my computer beeps very long so i turn it off. i thought it was the cpu overheating. i put some thermal paste and turn it on when the computer is in the desktop...
hi Robin.
if your computer is making a beeping sound when it starts. No, you're not crazy, your computer really is beeping, and the sound may be coming from inside your computer, not your speakers.
These beeps are called beep codes and are used by the BIOS (the software that runs your computer hardware) during the POST (an initial test to make sure your computer is OK to start) to report certain initial system errors. If you're hearing beep codes after you turn your computer on, it typically means that the motherboard has encountered some kind of problem before it was able to send any kind of error information to the monitor. The beeping, then, is a way to communicate a problem to you when the computer can't show a proper error on the screen.
Follow the steps below to determine what computer problem the beep code is representing. Once you know what's wrong, you can work to fix the issue.
How to Troubleshoot Beep Codes
Figuring out why your computer is making beeping sounds should only take 10 to 15 minutes. Solving that problem that you identify is another task entirely and could take a few minutes to hours, depending on what the problem ends up being.
  1. Power on the computer, or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're probably not going to make whatever problem you have worse by restarting a few times.
  1. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short (or all the same length), and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    I know this might all seem a little crazy but this is important information that will help determine what issue the beep codes are representing. If you get this wrong, you'll be trying to solve a problem your computer doesn't have and ignoring the real one.
  1. Next you'll need to figure out what company manufactured the BIOS chip that's on your computer motherboard. Unfortunately, the computer industry never agreed on a uniform way to communicate with beeps, so it's important to get this right.
    The easiest way to figure this is out is by installing one of these free system information tools, which should tell you if your BIOS is made by AMI, Award, Phoenix, or another company. If that doesn't work, you could open your computer and take a peek at the actual BIOS chip on your computer motherboard, which should have the company name printed on or next to it.
    Important: Your computer maker is not the same as the BIOS maker and your motherboard maker is not necessarily the same as the BIOS maker, so don't assume you already know the right answer to this question.
  2. Now that you know the BIOS manufacturer, choose the troubleshooting guide below based on that information:
    Using the beep code information specific to those BIOS makers in those articles, you'll be able to figure out exactly what's wrong that's causing the beeping, be it a RAM issue, a video card problem, or some other hardware problem.
  3. Try to turn off beep sound in the BIOS
More Help with Beep Codes
Some computers, even though they may have BIOS firmware made by a particular company, like AMI or Award, further customize their beep-to-problem language, making this process a little frustrating. If you think this might be the case, or just worried it could be, almost every computer maker publishes their beep code list in their user guides, which you can probably find online.
See How to Find Tech Support Information
Dec 13, 2017 | Biostar MCP6P-M2 Motherboard - v6.0,...
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Beeping and choppy sound
sounds like you're suffering from low memory
May 07, 2008 | Compaq Pavilion ZT3280US Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
