Lite On LiteOn 204Watt PA-4022-6B Power Supply (190050) Power Supply Logo
A
Anonymous Posted on Jan 25, 2011
What are the readings I should get when testing
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Jan 25, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
527933
Points
7608
1helpful
Good reading foe 2001 3.0 ranger crank sensor
You need to use OHMS and disconnect wiring. If reading is varying replace it.
Apr 09, 2022 • Motorcycles
I went to Harbor Freight to get a 12 volt light tester. It reads red for power and green for ground. I tested all my fuses under my hood.
You're not reading a ground you're reading the load of the circuit being tested. Look at the tail light fuse test it with the switch off and it will show a ground as it reads the circuit from the fuse back to the battery and the kajillion little sub-circuits then turn it on and it will test as Voltage.
2helpful
Emission test readings
if the test was just recently done have the customer go back to the place that did the test and ask for another printout. that`s the only way to get the readings.
1helpful
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 • GE Dryers
2helpful
I need to know how to test the ignition coil on a 1995 jetta
to test the coil you must use an ohm meter and remove the wire connections from the coil, first test the coil from B+ to the center coil wire tower, read the Resistance on the coil and write it down next test between the positive post and to the negitive post read the Resistance next test the negative side to the center post or tower read the resistance there should be no more than 2000 ohms resistance on any test and if it reads 0 resistance it means it's shorted and needs to be replaced, be sure to set the select lever to it's highest ohms resistance level before testing.
4helpful
2answers
Megger testing of wire insulation. what represents a good reading and what is a bad reading. Using a AMB45 (Amprobe) Is an "OL" good or bad?
Hi
OL is a good reading, it represents a reading of greater than 400Mohm, with any insulation testing the greater the value the better.
Thanks
Danny
2helpful
Codes for 1995 Mitsubishi eclipse
Engine-light-help.com
P1100 Induction Control Motor Position Sensor Fault
P1101 Traction Control Vacuum Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1102 Traction Control Ventilation Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1103 Turbocharger Wastegate Actuator
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
P1294 Target Idle Speed Not Reached
P1295 No 5 Volt Supply To TP Sensor
P1296 No 5 Volt Supply To MAP Sensor
P1297 No Charge In MAP From Start To Run
P1300 Ignition Timing Adjustment Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss Of CMP Or CKP Sensor Signals - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1400 Manifold Differential Pressure Sensor Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1443 EVAP Purge Control Solenoid '2' Circuit Fault
P1486 EVAP Leak Monitor Pinched Hose Detected
P1487 High Speed Radiator Fan Control Relay Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1489 High Speed Condenser Fan Control Relay Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1490 Low Speed Fan Control Relay Fault
P1492 Battery Temperature Sensor High Voltage
P1494 EVAP Ventilation Switch Or Mechanical Fault
P1495 EVAP Ventilation Solenoid Circuit Fault
P1496 5 Volt Supply Output Too Low
P1500 Alternator FR Terminal Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1600 Serial Communication Link
P1696 PCM Failure EEPROM Write Denied
P1698 No CCD Messages From TCM
P1715 Pulse Generator Assembly
P1750 Solenoid Assembly
P1791 PCM ECT Level Signal To TCM Circuit Fault
P1899 P/N Position/Transaxle Range Switch Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1751 A/T Control Relay
P1791 Engine Coolant Temperature Level Input Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1795 Throttle Position Input Circuit To TCM - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
Top Lite On Computers & Internet Experts
Steve Pack
Steve Pack
Larry Ng
Larry Ng
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
