Question about LG Heating & Cooling
Hello, Water comes from my system. The water is partially evacuated outside. It is not the first time and the company from which I have bought the unit does not respond to my calls. Michèle Gamache
    Master:
  • 726 Answers
Water comes from any aircon its really cold air that turned to condensation if there is heaps of water the aircon termostat is buggerd and making it to cold and makig the ice in the system
Posted on Jul 18, 2008
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Water sound when i accelerate my 2003 blazer
intake or vacuum leak? I dont know uless your more specific
Nov 06, 2011 | 2003 Chevrolet Blazer
Loud vibrating sound coming from hot water heater. Had gas company change meter and regulator. At first was losing hot water while in the shower. Went through check list after it coded out at #12, all...
Can't address other issues, but WATER pressure should be 40 to 80(I'd say 70)lbs. tester at home D for $10-15. Goes on hose Bibb outside, or at washing machine cold valve.
Mar 18, 2017 | Rinnai Water Heaters
I HAVE A KENMORE A/C THAT SPITS WATER INTO THE ROOM AFTER RUNNING ABOUT 15 MIN AT A TIME. THE COMPANY I BOUGHT IT FROM WILL NOT DO ANYTHING ABOUT THIS. IWISH YOU COULD GIVE ME A SOLUTION TO THIS PROBLEM.
While you didnt say i suppose its window a/c and not a certral unit
the drain for teh condensate water is clogged and the fan is picking up the water and "stipping it out" go outside and clean the drain in the corner of the cabinet
Aug 04, 2011 | Kenmore Kitchen Ranges
Kitchen Aid KSCS23FVMK less than a week old had the waterline installed two days ago. Everything was working well (except it seemed that the ice took forever to be made) until this morning when no water...
Slow water and ice, could mean that you haven't gotten all the air out of your system yet. I would suggest holding the lever down for water for quite some time to evacuate the air out. If I am right eventually water will start flowing.
Jul 01, 2011 | Refrigerators
I don't know how to open the shower. It only works the water below
Hello. At the bottom (spout) where the water comes out it have a pull button. Just pull it up and water should comes out trough the shower head. If water comes out without pressure and is partially comes from the bottom just replace the spout. (bottom part)
Aug 30, 2010 | Delta T13420 Chrome Classic Single Handle...
Takes 4 or 5 cycles to dry clothes.
Most of the time this problem is attributed to a blocked or more precisely, a partially blocked dryer vent system. When a dryer vent is blocked it stops the air flow and the heat backs up into the dryer turning the heat sensors on and off prematurely taking longer for the clothes to dry. Over time this may cause the heat overload fuse to blow and you will have no heat at all.
First take a look at the dryers ducting between the dryer and the wall to make sure the vent duct (normally a flexible style) has not been crushed or kinked.
If the dryer duct to the wall is in good shape then in most cases there is a blockage some where between the wall where the ducting connects to the vent and where it exhausts outside.
The major cause of a blocked dryer duct occurs when the water in the clothes is heated to a high temperature and turned into steam, which is then exhausted out the back of the dryer to outside. As the steam cools on its journey and gets closer to the outside of the house, it tends to get cooler and turns back into water droplets. This is going to be the point where the dried lint, as it escapes past the lint filter, sticks to the newly formed water drops and starts a gradual chocking down of the 4" diameter vent to 3",2",1" and finally stops all flow of air.
Remember, the dryer is designed to exhaust so many cfm's and the more choked the vent the more heat is backed up into the dryer.
If you cannot access the dryer ducting, because it is in the wall or ceiling, to look for the obstruction, then look in the yellow pages or contact the local appliance repair service company and get the name for a good duct cleaning company.
Apr 08, 2010 | Dryers
My Whirlpool Dishwasher Model # DU8000XX0 works perfectly until it is time to drain. When draining all the water comes gushing out the air gap on the counter. Pease help!
The problem is that the dishwasher discharges the water very rapidly...
Your drain pipe is either too small or partially plugged to the point that the water cannot get away fast enough...
You probably need to have the drain pipe cleaned, or aget some drain cleaner to put down it.
Heatman101
Feb 26, 2010 | Dishwashers
Water dispenser makes noise
sounds like your problem is a drop in water pressure on the water department side. is your facuets good? have water company come out (should be no charge if city water) and put a pressure gauge on outside of house.
Jun 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Coffee pot just would not brew this morning, though it worked fine yesterday morning. I emptied it and started over 3 times. The lights come on but that is all that comes on.
Check the water level. Check to make sure that the coffee filter under basket is clean and not plugged. YOu can remove your filter, then take out the basket and clean it....when did you purchase the machine?
Aug 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Heating & Cooling Logo
83 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
