Question about MSI PM8M-V Motherboard
Msi problem Ram is ok it is cheked by other Pc.And hard connection is smps it is also ok.I think main board have a problem.It wil be replaced
  • Anonymous Nov 11, 2008
    I tested the power source, changed the switch & 4 different types of ram that I knew worked. The light on the board turns on but, nothing else. Brand new board....
    any advice?
Motherboard MSI driver PH8M VIA VT8237 where is driver
Posted on Jul 18, 2008
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Thanks.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
MSI 845GVM-V (MS-7057-010) Motherboard cpu fan not ruuning but smps is ok when jpw1 is disconnected then fan is running but mother board is not on
Hello hare is the homepage:
http://www.msi.com/product/mb/845GVM-V.html#/?div=Manual
Try to download the manual, and check all your connections again.
Try also to renew the power supply.
Check also this site:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
The jpw1 is the main power connection for power to the cpu:
So you probably have a bad power supply.
Good luck
Jan 25, 2013 | Computers & Internet
WHEN JPW1 PORT I S CONNECTED THEN MOTHER BOARD CPU FAN IS JUST ON AND OFF WHAT IS THE SOLUTION OF THAT SMPS IS OK.
Good luck
Jan 25, 2013 | MSI 845GVM-V (MS-7057-010) Motherboard
NO Post, No Display & No Beep. I have an MSI 045GCM5-F V2 Mother Board & Intel Core 2 Duo Processor. Plz help.
That is a symptom of burned SMPS or RAM. Try to replace SMPS only cost worth about 20$
Jul 29, 2010 | MSI 945GCM5 Motherboard
When i turn on computer the screen is blank. I have had it sent in before and it was the motherboard and it was fixed under warranty. Now it is not under warranty/
try inserting the operating system disk and boot up off the cdrom. your bios should be adjusted to boot up from c: - cdrom - a: [if you have a floppy drive]
Oct 18, 2009 | Gateway M675 Laptop
Hitatchi 42pd5000 will not power up
pls. open H-output trangister and out side of pcb and check voltage B+ 135v dc is ok ?.
if yes.then ...H-OUTPUT trangister checked and replace
if not then check SMPS .
1.fuse
2.STR
3.output Dyode
check
1st fuse is open then check rectifier dyode cantunity. if sort then replace all 4 dyode.(rectifier)
and if dyode is ok .then check STR cantunity is sort then Replace with New STR but 1st 220uf/450v dc capaciter cheked / 2nd. in SMPS stage any P.F and capciter likage or sort cheked or chenged first after the NEW STR use
*. note: smps pcb checkd any dry canaction pls. Resolder first.
Oct 04, 2009 | Hitachi Televison & Video
MSI FX5200-T128 :: Hard-Freeze
You could try using the driver for the FX5200 directly from Nvidia. Maybe the MSI drivers are causing the issue. If not try using the video card in another computer and see if it works. Without testing the card or the board it is hard to say. Sometimes a weak powersupply can cause problems like this. Also make sure if there is a power connection to the video card that it is hooked up. Some video cards need additional power plug hooked up.
Sep 10, 2009 | MSI FX5200-T128 (128 MB) Graphic Card
Msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
Dec 01, 2007 | Intel Motherboard
MSI PM8M-V Motherboard Logo
121 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
