Question about Apple Canon CanoScan N670U Flatbed Scanner
Using PaperPort 11 to scan
When I use PaperPort 11 and CanoScan the scanner is cutting off the sides and they are not being scanned.
  • colin john Feb 19, 2009
    exact same problem... what is the solution
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Posted on Jul 13, 2009
The paperport is preset to scan in Letter size rather than A4. Go to "Scan or Get Photo", select a profile, eg. "Grayscale Document", uncheck "Display scanner dialog box", then click on "Settings...". On the pop up window, switch to "Scan" tab and change the "Size" from "Letter" to "A4" or appropriate.... no thanks.. I was looking for a solution to how come on some Paperport the "Display scanner dialog box" gray out and cannot be unchecked. Paperport is more expensive and getting worse. If you don't have your scanner switch on and plug in, an error will comes out when yo are on the "Scan or Get Photo" page... a kind of super stupid.
Posted on Aug 29, 2008
When I scan, using the ADF on my brothers mfc 6490, the resulting image is shifted, cutting off the right hand margin of the 8-1/2 x 11" scan. I am using Scansoft Paperport on my XP Pro laptop. The...
I read the whole paragraph and could not find a question, so I will try a few suggestions.
When you scan, select the option to open the scanner interface. It will give you more control on what you scan.
From the flatbed
When the scanner interface appears choose to Preview the scanned area. On the preview image click neat its border and you will see a dotted/ interrupted frame. Play with the borders of the frame to select the area. Intelligent software like Adobe Acrobat rotate the image to right it.
From the ADF
Check the alignment of the paper on the document feeder. Test the first page and see if it is correct. If it is, and all the subsequent pages have the same margins use the ADF If not, maybe you should use the flatbed.
Oct 29, 2013 | ScanSoft Nuance PaperPort 11 for PC
Hp laserjet 2010 prints black line down side when printing scans from paperport 11
I have no idea what "paperport 11" is.
That being said, normally a line down the page when copying or scanning is caused by dirt on the Automatic Document Feeder glass, Not the flatbed glass. It is a thin strip of glass to the left of the flatbed scanner glass. Clean it.
Jan 11, 2011 | HP Office Equipment & Supplies
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
Enable Duplex Scanning
You cannot scan both sides using a flatbed scanner! If you want both images on the same sheet, you need to scan twice and using some imaging software you can cut and paste the images appropriately.
S. Mohan
Jul 30, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
HP5550c scanner using Paperport 7.0LE - slow scanning
Have you noticed any quality difference in the scans? Sounds like it is set to scan at a higher resolution which will take longer.
Dec 18, 2008 | DPI TravelScan-PaperPort 7.0 LE 230UP ((((...
Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
Jul 18, 2008 | Epson Perfection 1250 Flatbed Scanner
Apple Canon CanoScan N670U Flatbed Scanner Logo
2,080 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
neOen
Level 1 Expert
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
