Haier 9,000-BTU Portable Air Conditioner
I own the Haier 9,000-BTU Portable Air Conditioner - White
For two days it was been blowing out a really bad smell. Today I checked my unit to find out that there was a leak on my floor. This chemical leak is the same smell that my unit is blowing out. What should I do?
  • 230 Answers
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Posted on Jun 27, 2008
  • 230 Answers
SOURCE: Haier Air Conditioner (24000 BTU, 240 electric)
The compressor is probably bad. This is what some do when they are failing. The compressor is the heart of the unit and very costly to have replaced. Only a licensed technician can do this for you. The EPA regulates the refrigerants used to complete this job. In most cases it is cheaper to simply replace the unit then to fix it. If it is new I suggest exchanging it for another one on warranty.
Posted on Jul 08, 2008
SOURCE: My Haier 8,000 BTU air
I had that same problem, find the remote and use that to turn it on / off. It solved the problem for me, for whatever reason. You will need to use the remote until the buttons start working again, took mine a few days. I have no idea what was wrong with it.
Posted on Sep 06, 2008
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
  • 3600 Answers
SOURCE: I have a Haier 8000 BTU Air conditioner and it smells sooo bad.
you need to replace the air filter and shoot some fabreeze intothe ducts and clean the water pipe drian.
Posted on Jul 23, 2009
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
Unit triping braker when compressor turns on
the breaker is underrated the power that it takes to start the compressor is really big but only for a few seconds. That is called the inrush and the breaker should be rated for HVAC wich allows for this.
Mar 15, 2011 | Fedders 9,000 BTU Electronic Portable Air...
What does E1 stand for in a window air conditioner unit - Haier brand
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 27, 2010 | Haier Portable Air Conditioner, Electronic...
Demby portable Capacity: 11,000 BTU air conditioner
This unit is sized to approx a 35 square metres area at a normal 2.4 metre ceiling height. All I would recomend without actually seeing the problem is to check this measurement and close all windows and doors. The unit is most likely undersized, but check the air temp coming off the unit. It should be about 10 degrees.
Aug 15, 2009 | Heating & Cooling
Jul 08, 2008 | Haier hwr10xc6 Air Conditioner
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Remote is not working anymore...how to control temp??
I bought the 9,000 btu and the remote stopped working the second time I used it. I returned it and bought the 7,000 btu and the exact same thing happened; it died the second time I used it. The only thing I noticed, not sure why, but if I take the batteries out of the remote for a while and put them back in, it works. Not being able to control it without the remote is definitely a design flaw.
May 14, 2008 | Haier HPAC99ER Air Conditioner
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
