Question about RCA Universal Remote Control
I need a code
For Sonicview sat
  • lrcandler Aug 25, 2008
    need the code for rca control for a sanyo tv that is on video and can't get off
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): I need a code - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Ir code for sat box
Search for LIRC (Linux Infrared Remote Control) on sourceforge.net.
I found codes for my SonicView SV-1000 there. You can then search download an appropriate text file for your sat box, so that your computer or tablet can beam codes to your set top box. Welcome to http lirc sourceforge net
Mar 17, 2015 | Televison & Video
What sonicview 360 Elite pvr remote code?
0018,0019,0014,0011.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 19, 2014 | Sonicview Universal Remote Control for...
Sharp tv troubleshooting
need code for my lg lw5600 tv so my sonicview remote would work
Oct 25, 2013 | Televison & Video
What is the TV setup codes for LG TVs for the SKY remote?
Here are the codes for LG TVs for the sky remote.
Codes provided by SKY:
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367.
Codes provided by LG:
0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851
Regards,
sjstore2
Dec 18, 2010 | Televison & Video
Sonicview 360 Elite Dual w/ Dish500dpPLUS EXC! signal cant watch!
You need to use a sonicview splitter and then go into your settings and select proper ports.If you have 2 wires comming from i duel lnb or 2 stats then you install then in the splitter then one wire into your reciever.then you scan the sats on the ports you have them hooked on to. example echostar110 port 1 also tp setting is 12258 Then echostar119 port 2 also tp setting is 12239 then scan. Scan on autoscan. hope i helped :)
Mar 01, 2009 | SMC EZ Switch SMCGS24 24x1000 Mbps
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
Satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Sep 02, 2007 | Audio Players & Recorders
Televison & Video Logo
157 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
