Question about JVC AV-32F476 32 in. Television
Lightening Strike - TV won't turn on (remote or manual button)
Same as subject
  • 3 more comments
  • PAUL MC G
    PAUL MC G Jul 19, 2008
    The TV was NOT on. Yes, it was plugged in. Yes, cable TV coax was connected. I suspect standby circuitry damage, but don't have schematic/wiring diagram to locate components. I have a Diode, Transistor/FET tester (in or out of circuit) and am checking any and all transistors/FET's I'm wondering if the large IC chip was 'zapped' (8812CSDNG5JB4 - TOSHIBA, Main Board) or the Tuner Board IC, (TA1218AN - TOSHIBA). The main board fuse is intact (no damage). Have checked components on front panel circuit board - no problems found. I know lightening strikes are unpredictable and can wreak havoc in electronic circuits (especially IC's). Four TV's in the house were also plugged in, three w/cable TV coax connected, one of which was 'ON' when the lightening struck, only the JVC set was affected (which was also OFF). Other electronic appliances/equipment were also affected (printer, wireless router, digital clock/radio/phone, cordless phone, etc.) If you have a copy of the schematics for the JVC AV-32F476, would you e-mail them to me?
    Thanks.
  • repairtech38 May 24, 2009
    Hello. can any one please tell me where i purchase this part.
    8812CSDNG5JB4
  • PAUL MC G
    PAUL MC G Sep 07, 2009
    TV was OFF when it happened.
  • jhun T
    jhun T May 11, 2010
    Was the unit ON when the lightning striked?
    If it was not on, was it plugged to the wall?
    Does it have a cable tv connection?
    Lightning damage is unpredictable...frontend or power supply circuitry...might be worse. Better have it checked with an expert technician to asses the damage or else ditch it for good instead of spending unnecessary costs.
    -HTH(hope this helps)
  • Gerald Frank Jul 13, 2013
    I have a Hyundai Tucson 2 litre,son replaced the oil pump, i need to replace the crank shaft pulley, do i fit the cam gear the the spacer or the other way around, desperate
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 1,001 Answers
  • Multi-color,silver,golden,rose gold decide your choice which you like.
  • High-speed,transmission rate synchronization and transfer music, contacts, quickly and efficiently.
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
  • Perfect for your some Apple device , high speed data transfer will make you have a good time .
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters USB Charger Cable for Apple...
Posted on Dec 27, 2016
    Sergeant:
    Champion:
  • 341 Answers
Sorry, I don't have a schematic diagram for your unit.
I guess the lightning path zeroed-in to your JVC tv. Goodluck anyway!
Posted on Sep 08, 2008
    Problem Solver:
  • 5 Answers
First, you will want to determine where exactly did the lightning go through. It could have came from the power cord, or it could have been your cable/satellite. To do this, unplug your TV and open it up. check the inputs for the power source as well as cables. Follow where the cables go and check the nearby components. See if anything is visually broken, burned, or fried. Chances are decent that there are going to be some blown components that you can visually see.
At this point you need to determine the damage. it could be as simple as a couple blown fuses. if you are able, test the different components and determine what needs to be replaced. if its easier you could see if you can replace the fried board itself. Generally there are multiple circuit boards inside a tv. there will be one for your power supply, an inverter board as well as others.
Its really hard to tell what exactly is broken without actually seeing it TV, and there is a chance that its just time to buy a new TV.
Lastly, if you don't have experience with electronic components or feel uncomfortable opening up and messing with your TV, take it into a good shop and see if they can diagnose/fix the problem. It can get expensive but a lot of the time its cheaper than buying a new TV.
Hope I helped
Posted on Sep 30, 2009
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
My dynex tv wont turn on! the strom knocked out our power, now the power is back on the tv wont turn on from remote or tv power button.
Lightning is a weird beast, and can do strange things to a TV. Sounds like the set took a hit. If there is a fuse then check it on a volt-ohm meter for continuity while it is out of the circuit, and if it is an open circuit, replace it. If there is a circuit breaker, then reset it. If these don't work, look for obvious scorching on the circuit board (assuming you know how to avoid electricution, otherwise do not touch). Lightening can literally jump around on a circuit board, so there is no way to know what part of the set was effected by the strike - the lightening will not always burn out the first circuit it touches, but will burn out something further into the circuit. The most obvious place to look is around the transformer and rectifier circuits. If a capacitor was hit, it may be swolen or discolored; resistors will scorch, and the worst thing is that transistors and IC's often show no damage - in fact, any part might be burned out and not show visible signs. If nothing is obvious (like scorch marks) and the fusing is intact, there are too many possibilities to begin listing them all. The fact that it won't turn on at all sounds like it is probably a power circuit, but, not necessarily. FYI turning a set off during a lightning storm does not protect it, you have to unplug the AC power cord and the line that feeds the signal into the set. Even circuit protection devices (lightning arrestors) may not protect against a close strike. Maybe the techs at Best Buy can supply more suggestions (Dynex is their brand).
Aug 29, 2011 | Dynex DX-L42-10A 42 in. LCD TV
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Altec Lansing ACS45.2-Lightning strike
There is a good chance with a lightening strike that damaged so much of your equipment that this device was also affected. power to the device doesn't necessarily mean that other components were not damaged.... you can elimanate speaker damage by hooking the speakers up to another device to check them.
Robert
Sep 15, 2008 | Dell PART NUMBER KIT SPEAKER MM ACS45...
Suspected lightening damage
yes ligthning damage your unit because of static electricity that increase the power of your power source
Aug 09, 2008 | JVC AV-27530 27" TV
Possible lightening strike
Lightning will create a lot more damage,the vertical circuit has become defective,the repair should not be expensive better be safe and call a qualified technician.
Sep 18, 2006 | Sampo SME-27FDL5 27" TV
JVC AV-32F476 32 in. Television Logo
636 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
