Question about MSI PM8M-V Motherboard
Msi pm8m3 -V H
WHEN I GIVEN POWER BY USING SMPS MOTHERBOARD CAN GATE POWER,BUT CPU FAN CANT RUN PROPERLY AND NO DISPLAY.
PLS GIVE SOLUTIONS
  • 2,794 Answers
Check the memory cards and see if there seated properly. Check your hard connections.
Posted on Jul 18, 2008
Ijrgha'eongdagda
Posted on Jul 20, 2008
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
There is power but no display and after few second the system fan stop how to solve this problem sir pls..
If you are using the PC there is problem in SMPS which can not deleiver the proper supply to the fan of motherboard so you should change the SMPS to solve this problem
If you are using a laptop then you should check out the display IC socket or check through VGA port if VIDEO available then your LCD is faulty you should repolace it with new one..
or also check the power controller card.
please give your ratings.....Thanks to giving me chance to help you...
Mar 30, 2011 | Computers & Internet
MSI PM8M3 V motherboard with intel celeron D processor
If i am right, it's nothing serious, perhaps your Bios battery has been removed or insufficient voltage. You can replace the battery. Regarding "floppy disk fail", enter the Bios settings and disable the "floppy boot seek", this will fix your problem. Still problem? do let me know. Good luck Thanks for using FixYa.
May 31, 2010 | MSI PM8M3-V Motherboard
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Psu
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
NO SCREEN DISPLAY WHEN BOOTING ON MSI MOTHERBOARD
first see pulg or correctly put
Then remove the fan and insert properly after completing then start the computer if u face again same problem i think fan is goan
Jul 31, 2008 | Intel Motherboard
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
MSI PM8M-V Motherboard Logo
912 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
