Question about Refrigerators
CAn i put a small freezer in a cupboard and have it work properly?
    President:
  • 1,462 Answers
Only if there is ventilation. if freezer gets cold, then something else has to get hot and you have to be able to get rid of the heat
Posted on Jul 18, 2008
My bush fridg freezer is hot on the side, what could this probing be? Thank you
That is the heat exchanger radiating the heat from the freezer. Perfectly normal but make sure there is the correct air gap against the wall and cupboards etc.
Jun 20, 2017 | Bush Refrigerators
Hi ive hoover hrfa54w fridge freezer just over a year old. Ive noticed freezer is starting to defrost sometimes the freeze again....its in a holiday cottage so often in a very cold ambient temperatur
Ambient temp will cause the thermostat some confusion. There's probably nothing wrong with the fridge, my freezer doesn't like being in the outhouse. Only alternative is only switch on when you are there or move it to a cupboard where you could put a low output source of heat just enough to keep it happy. Then get it out when you are there?
Jan 25, 2015 | Hoover Refrigerators
We have a Maytag Model # MF D2561HES, side by side, freezer drawer below. It is a quarter of an inch too high for the space. Is it possible to remove the wheels from the bottom in order to solve this...
The last one of these that I had that issue with could not be fixed that way. The only thing that you can do is remove the cupboard that is above it and use a table saw to trim 1/2 inch off the bottom of the cupboards.
Jan 20, 2014 | Refrigerators
Does the table top bush dishwasher need to be on a table top for gravity drainage or can it be in a cupboard?
no it can be in a cupboard it does have a drian pump a small one which will pump up to 3 feet from the base of the machine,cupboard installation work fine on these appliances.
Nov 01, 2010 | Dishwashers
The door handle is partly pewter and has snapped off at the Anchor. size from screw hole to screw hole 300mm
As it is and old model the genuine part is not available so I have had to make a plan. I have used a built in cupboard handle in Stailess steel and modified it to work. Anchoring the handle from the front will not work, so I have had to srtip the whole door and place small indentations in the foam insulation with washers behind the anchoring nuts.336b095.jpg
Dec 03, 2009 | Freezers
How do I install mothballs in my camper?
I saved some of the small plastic containers that margarine comes in ( I like Country Crock ) lol But any small plastic container with a lid would work. I poked holes in the lids and put the mothballs in the containers and placed the containers in different cupboards and closets throughout the camper. Hope this helped and best wishes.
Sep 29, 2009 | Sport & Outdoor - Others
HELP dropped my phone in the toilet
pick out the battery and sim and dry it off properly and dont try to start i again for att lest 3-4 days and then se
Jul 28, 2009 | LG RUMOR Cellular Phone
Dishwasher cupboard front
typically there is a metal trim around the wooden front. on the sides of the dishwasher door you will see some small screws. remove those screws and the wooden panel can be easily removed.
Feb 14, 2009 | Dishwashers
The cupboard next to dishwasher becomes full of condensation during drying cycle
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Sep 03, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
