Question about Sony VAIO VGN-FS640W Notebook
Sony Laptop Screen goes Grey
While using the laptop the monitor will occasionally go grey. Power is still going to the monitor thus it isn't black. I don't think it is the inverter because I can't read anything on the monitor (my HP inverter went bad and this is different). Also, it will work again if I put the computer to sleep/suspend it/turn it off and then wake it up/unsuspend it/turn it back on. I also tried an external monitor and that works.
Any help would be appreciated.
    Scholar:
  • 144 Answers
1.What I need you to test is...When laptop monitor go grey try plug external monitor and see that it work fine or not ??
2.Incase it work fine try to give a little tap behinde the laptop monitor and see that any changes...keep try and harder and see
3.Incase if you gave a hard tap also and its still the same but external monitor work fine then....I think you have problem with your LCD monitor coz there are chips that control the LCD crystal and maybe when it goes hot it behave this way....in this case you can't change the chip...you have to change the LCD.
takecare.
Posted on Jul 18, 2008
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
Half of my laptop compaq presario cq42 screen is grey
You can check the screen using an external monitor. If the external monitor is OK, the internal screen is faulty. If not, you may have a GPU issue.
Nov 29, 2013 | Compaq Computers & Internet
Laptop screen divided
Try connecting the laptop to an external monitor if it works well. Be a problem in the laptop screen
May 09, 2013 | Sony VAIO PCG-K23 Notebook
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Dell Vostro 230 monitor goes blue, grey, jumps around
Check with the LCD by attaching one side to the LCD and other side to the laptop. If display is clear on the LCD then your laptop's screen have some problem otherwise your laptop's motherboard have some problem
Dec 26, 2012 | Dell Vostro 230 Safe space Tower w monitor...
Acer aspire one ZG5....connected to another monitor pressed control key and F5. The other monitor starts to boot up windows, gets to a certain point and then shuts off connection from acer laptop, who's...
As by your description, your mainboard of the laptop is faulty as the unit fails to produce a good picture on both its own LCD and on a external LCD
May 25, 2010 | Acer Aspire 5100 Notebook
Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
Jan 09, 2008 | Acer Aspire 3000 Notebook
Grey screen
Are you able to adjust the contrast or brightness? Try to turn them down to about 50%.
Jan 08, 2008 | HP f1905 19" Flat Panel LCD Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Sony VAIO VGN-FS640W Notebook Logo
412 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
