Question about Hunter 22451 The Brookline Brushed Nickel Ceiling Fan
Fan stops working for days
The fan will stop working for days and sometimes weeks, then it will just come on. The light works and we can hear it click when we turn on the different speeds but it will not come on during the down time.
  • Anonymous Mar 24, 2014
    just stopped working but fan assistand did
  • 417 Answers
sounds like theres some sort of radio interference in your house, you can try to change the code for the fan, turn off the breaker at the fuse box then in the canopy above the fan near the ceiling is the dip switch for the fan, you have to remove that cover near the ceiling and look for a tiny set of switches and change the position of them , also in the remote you have to take the batteries out and change that code in the remote so it matches the new code you set in the canopy. if it still does it you can try to unplug all of your cordless phones and wireless routers in the house, anything that you have with an antenna and turn it off and unplug those to see if that helps the situation.
good luck
J
Posted on Aug 07, 2008
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Renault Megane Dynamique 1.6 2004 - Heater fan stopped working - wet front footwells
Im almost sure that your problem is a broken or leaking heater core and needs to be replaced cose 1 your coolant level allways will be low due to the leak and 2 it could damage your blower fan motor. if in winter time you need the heat fixit... If not you could cancel the 2 waters hoses going to the heater core. hope this helps.
Jan 28, 2014 | Cars & Trucks
Sony KDS-R50XBR1 /(2005) Red stand-by light blinks 4 times.Tried new bulb (Philips) 1 week ago ,same problem as before .Whole new light engine replaced two yrs ago by sony.What happens is it will turn off...
The error code of 4 blinks indicate a fan problem.the fan is slowing or internitantly stoping. the fan is stallling. or the fans not getting power. Always rember anything that moves will eventally stop. this fan is on all the time. also there more than one fan. Listen closely to hear the fan. The fan is not difficult or exspensive repair.
Mar 04, 2011 | Sony KDS-R50XBR1 50" HDTV
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Clicking from Condenser
I would have to say it's your fan going out, also if the units aren't fixed the the DD should come out and fix it for free since it wasn't done the first time. I would take a look at it but I don't know where in florida you are. I'm in highlands county. If your close enough I could come take a look. If there's clicking coming from your condenser then it's one of two things, the compressor or the fan. hopefully the fan. let me know.
Sep 29, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Hunter 22451 The Brookline Brushed Nickel Ceiling Fan Logo
157 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
