Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Picturemate printer head not cleaning
I have performed the printer maintenance at least 15 times and still no yellow ink. What else can I do?
  • bigdm1949 Nov 12, 2008
    I have cleaned the print head numerous times and I have no yellow.
Mix-it-up
  • 832 Answers
SOURCE: Not printing too well
Do use genuine brother ink for testing: If you're lucky the filter in front of the nozzles (which is part of the printhead) is not clogged. Do the power cleaning twice: power up. push menu then start mono then four times arrow up. machine will display maintenance. push arrow up several times til 7 is displayed then Enter then arrow up til 6 is displayed. Push Enter. push arrow up til 3 then Enter: P cleaning_all Push start/mono. After machine has finished maintenance will be displayed. push arrow up til 0 (zero) then enter then puh arrow up til 9. machine will print a test sheet. Repeat procedure above if no good result. After three times without success the printhead is clogged due to wrong ink. ...and do use dye-ink only for brother printers (pigmented ink will clog the filter!)
Posted on Sep 14, 2007
jimmynuetron
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
  • 79 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Posted on May 01, 2008
SOURCE: My canon pixma /ip3000 printer
Repeated deep cleaning (about 12 times) has started to get the ink flowing again, I am printing something every day and hope the problem clears up totaly.
Posted on May 09, 2008
SOURCE: My yellow ink cartridge won't print only, I REALLY HAVE TRIED EVERYTHING
What kind of bathroom cleaner worked? exact name? Thanks
Posted on Aug 16, 2008
How to clean printhead pm260?
Note: If you see a Print Pack low message on the photo viewer, you may not be able to clean the print head until you replace the Print Pack.
  1. Load paper in PictureMate so you can print a nozzle check pattern after cleaning the print head.
  2. Press Menu.
  3. Press the arrow buttons to select Maintenance and press OK.
  4. Press the arrow buttons to select Auto Cleaning and press OK.
  5. Press OK again to clean the print head. Cleaning takes about 60 seconds. PictureMate makes some noise and you see an Auto Cleaning message.
    When cleaning is complete, PictureMate prints a nozzle check pattern.
  6. Check the pattern to see if there are any gaps in the lines.
  7. Do one of the following:
    • If there are no gaps, Press OK.
    • If there are gaps, Press the Back button.
  8. Follow the instructions on the screen to clean the print head, check the nozzles, and repeat the process as necessary.
If you don't see any improvement after cleaning the print head up to 4 times, turn off the product and wait at least 6 hours. Then try cleaning the print head again. If quality still does not improve, one of the ink cartridges may be old or damaged and needs to be replaced.
Sep 09, 2014 | Epson PictureMate Snap - PM 240 InkJet...
Can you Help me unclog my nozzle? Epson Picturemate PM240. Head cleaning 3x not successful: no blue ink at all. Print cartridge is brand new and showing 100% full. It tells me to replace the print...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 18, 2011 | Epson PictureMate (C11C556001) InkJet...
All my picture from my Epson Picturemate personal photo printer are coming out pink. I have brought a new cartridge and it is still coming out pink. Why??
Hi!
You need to run a Head Cleaning cycle so printer can get rid of the old ink from your previous cartridge. Try running it from maintenance for at least twice or try printing pictures in between cleaning cycles.
Hope this helps.
May 05, 2011 | Epson PictureMate (C11C556001) InkJet...
My PictureMate printer is printing with a discoloration border on each end of the print; blue on the left and pink on the right. I have used photos downloaded from a SD card and also sample pictures from...
You often fix this by going to settings and going to things concerning ink and often their are cleaning options, like head cleaning and stuff like that.. It should fix it :)
It is great to set up dates when you will make your printer perform this cleaning.... It makes the printer perform better and just keeps it clean :) God Bless :)
Jan 08, 2011 | Epson PictureMate InkJet Photo Printer
I have an Epson Picture Mate Charm Compact photo Style C11CA56203-N. The pictures are coming out yellow and I've tried 3 different brand new ink cartridges, is there a way to fix?
Hi!
Did you run a Head Cleaning Cycle after changing the ink cartridges? Run at least Three head cleaning cycle to clean the nozzles of your printer.
Hope this helps...
Dec 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Put in new ink and it still won't pick up the pink and maroon. When I print the red tones they look yellow cause these cartriges arn't being used. How do I get the printer to grab these colors. It won't...
You must perform the "clean head" utility.
Go to
[Start]
[Printers and Faxes]
right-click on your printer and select [Properties]
[Maintenance] tab
Clean print head or other maintenance utilities.
You may have to do this 2 or 3 times.
Oct 11, 2009 | HP Photosmart C6280 Printer
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
My pictureMate 500 prints green only
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
. If all fails call epson for replacement.
Hope this helps
Nov 15, 2008 | Epson PictureMate 500 InkJet Photo Printer
Color bad
Follow these steps to clean the print head using the control panel on the printer:
1. On the Main Menu, press UP or DOWN arrow to highlight More Options, then press OK.
2. Press UP or DOWN arrow to highlight Maintenance, then press OK.
3. Press UP or DOWN arrow to highlight Clean Print Head, then press OK.
4. Press OK to begin cleaning the print head.
*NOTE: The cleaning takes several seconds, during which the message 'Cleaning print head. Please wait.' appears on the screen.
5. When cleaning is complete, you see a message asking if you want to print a nozzle check pattern. To see if the nozzles are clean, load a sheet of photo paper, then press OK to print the nozzle check.
6. Check the pattern to see if there are any gaps in the lines. If there are gaps, press OK to clean the print head again. If there are no gaps, press Cancel to go back to the PictureMate Main Menu.
Jan 03, 2008 | Epson PictureMate (C11C556001) InkJet...
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
817 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
