Question about Samsung HP-R5072 50 in. Plasma HDTV
Shut down problem
The problem is that the TV shuts down after about 10 to 15 Min. It just goes black and you can not turn it on again. For all I know, it is still on but the screen is black and the sound is gone.
It does seem to make some noice out of the switching power supply but I'm not sure.
Any clues?
Thanks TK
  • 61 Answers
Are the lights in the front flashing? How long have you had the tv. The lamp is probably the issue....they forget to tell you that they have to be replaced every so often and they are expensive. You will need to take the lamp out and make sure you get the correct replacement. I found one reasonable priced on the internet by searching for the model number shown on the old one. You can change it yourself if you are handy at all and have the manual. My friend did not have her manual of course so I had to find that on the internet as well.....Good Luck
Posted on Jul 18, 2008
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
2007 Panasonic 50in Plasma shuts off after being on 30 min sleep timer off, is the problem the cooling fans out/ over heating
Yes, cooling fan could be a problem. Just see whether it goes off during before shut off. If yes, the TV might need service. To know whether the fan goes off first or the TV, stick one side of any thin vibrating membrane such as a silver paper (like the one you see in cigarette packets) on the fan outlet, without blocking it, so that you can see whether it stops before the TV shuts down. Alternatively you can hand an inflated balloon which keeps flying off from the area of the fan and shall stop when the fan stops. I suggest this, in order to save your time looking at the rear all the time until the TV stops. Even then, one is likely to overlook whether the fan stops or TV stops first.
Aug 29, 2012 | Panasonic Televison & Video
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
L32
there is something overheating in your tv...
the causes of this might be the vents are being blocked, maybe they have too much dust or there is a tshirt or a towel on your TV.
there could be some resistance, fuse, or transistor overheating making it to shut down to prevent a massive burn out briking your TV
if its a PC.. in wich im not sure if its a tv or a PC.. but if its a PC, its that the CPU isnt getting enough vent.. so replacing the thermal past from the CPU and heatsink will make the temperature go down, also, try checking if the small ventilators are working correctly.. if the dont, change them all.
to make cheap fast repair.. get an air conditioner or a huge ventilator and make the thing get some air
Dec 18, 2007 | Vizio L32 32 in. LCD HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
