Making a network
Hello i cant get my netgear wireless-g router to network from my hp computer to my gateway computer every thing is hook up correct i just dont know what's the problem
  • Jamie Lynn Belanger Banta
    What exactly are you trying to make happen? Are both computers connecting wirelessly to the internet through the Netgear? Or is one computer physically plugged in directly and the other one connecting wirelessly?
    Since you state that everything is hooked up correctly, does that mean that both computers are successfully accessing the internet?
    Are you trying to share files between the two computers?
    If file sharing or printer sharing is the problem, there are certain steps that must be followed to get the computers to talk to each other even if they are both connected to the same router.
Please answer all the question of lucentrip... for us to know how to handle such problem...
thanx
Posted on Jul 25, 2008
Connection from computer
If the printer is connected via wireless it may not be set up correctly, as a network printer.
Connect it up via a USB cable to make sure it works, then change it to Wireless configuration and re-install it as a network not a USB printer.
Feb 25, 2014 | NetGear Wireless N 300Mbps DSL Gateway
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
Netgear cant connect to ipad
I think you should check the wireless settings of the router netgear router and the iPad .
Do you have any other wireless computer or device in the network?
Can you connect any other computer or device to the wireless network?
If your wireless network is secured then make sure that you have the correct network key.
See the links below:
Netgear router setup
How to connect iPad to Wireless network
Apr 21, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
I cant hook my netbook up to the netgear router. I need help hooking it up.
Please search for an available wireless network from your laptop. You will notice an available netgear router, please connect to it.
Jan 08, 2011 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Can you help me configure my netgear router? I cant seem to connect to http://192.168.0.1
you can try typing in your browser address bar www.routerlogin.net then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be 192.168.1.1 this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
Jun 21, 2010 | NetGear DGND3300 RANGEMAX DUAL BAND...
Xbox 360 connection withthe netgear WGR614v9
This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Router won't do ethernet to set it up---previously set up in another apartment, now when i go to set it up here it jumps straight to wireless but wireless isn't working.
  1. Disable the Wireless Adapter on your computer.
  2. Hold the "Reset" button on the pack of the WGR614 for 20 seconds(might need to use a paper clip/small pen)
  3. Connect an ethernet cable from one of the numbered ports on the Netgear and connect it to your PC
  4. Click on "Start", "Control Panel", "Network and Internet", "Network Connections" (or on Vista, "Network and Sharing Center", then "Manage Network Connection")
  5. Double-click on the "Local Area Connection"
  6. Click on the "Support" tab (or "Details" on Vista)
  7. Make sure an IP address and Gateway are listed. With netgear it should be 192.168.1.1 or some models are 192.168.0.1 for Gateway. If you get 169.x.x the network cable is probably faulty.
  8. Open web browser
  9. Type in the address of the default gateway(probably http://192.168.1.1) (Default user: admin, default pass: password)
You can re-enable the wireless adapter once you've configured the router. Make sure to pick a Unique SSID. (Unless you already are familiar with where to locate the saved wireless profiles on your computer so you can delete the old profile when the settings do not match)
Oct 04, 2009 | NetGear WGR614 Wireless Router
I see netgear as wireless option but it wont let me login to it. I dont understand. i cant find my cd to re dowload. how do i get my computer back to communicate
I believe you need to hook up an ethernet cable from your computer to the Netgear and go to the gateway address in your browser. It may be http://192.168.0.1 .. when you see the menu, configure from there instead of using a CD
Jul 09, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Setting up wireless network 4 computers with Netgear
Assuming they all will work with the version of wireless the netgear works with (802.11a/b/g) then you really just need to enable the wireless network on the netgear and choose how you want to protect it. I recommend using WPA or WPA2 if all your devices will support it - this depends on the wireless cards in all your pc's - just set up a name for the wireless network (not recommended that you use the default because everyone does) set up your WPA/WPA2 passphrase on the netgear and it should be pretty much ready to go. On each pc then, once they are able to see the wireless network with the unique name you gave it, just hit connect in your wireless settings and enter the passphrase. Each pc should be set up.
The only other thing to consider is to make sure they are all using DHCP via the wireless router or, if you prefer setting up their IP addresses manuall, make sure none of them conflict with eachother (each one needs to be unique).
Jul 15, 2008 | NetGear Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
