Question about Maytag Neptune MAH5500B Front Load Washer
Washer fills with water and thats it
When I start my neptune it fills with water and then it doesnt do anything else I opened the back up and you can hear the motor bump on three or four time every 20 seconds it will try to spin the drum but never does. I put in spin cycle and it never started spinning the timer counted down to 0 went off then came back on saying 1 min and stayed that way and the drum would still try to spin every 15 to 20 seconds. I then started to spin the drum by hand and it started spinning and kept on spinning the timer never went off 1 the pump would come on and off after it counted down to 1.
Also when the machine was off it would try to spin the drum
    Scholar:
  • 50 Answers
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Posted on Jul 18, 2008
Maytag neptune washer code FL and DO
FL means the door failed to lock
DO
means washer door is sensed as being open.
Aug 19, 2016 | Maytag Washing Machines
Had my maytag neptune top load washer almost 6yrs. Just changed the filter because of the code that was being read out. Now that code doesnt come on but the washer fills with water and just makes a...
What Codecame up before? NF for no fill?
What filter? are you talking about the water inlet screen?
Confirm the model number is it an FAV6800A machine?
How handy are you if you have to start troubleshooting the issue?
Apr 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My neptune washer has an indicator light that reads 'nf'. Can't find anything in the manual?
The washer has tried to fill and could not. Make sure the water faucets are open all the way.
Check for kinked hoses.
See error codes2_bing.gif on page 12 of the manual.
Dec 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH 8700 AWW
NF - No Fill
It means that the Washer does not turn on water valves to fill washer with water.
Try the following steps and the problem should be solved.
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Good luck.And please do rate my answer.Thank you.
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't agitate
open the back check the belt also see if u can turn it by hand. if that doesn't help call repair man .
Jan 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Nf pops up on the screen & the washer stops
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer wont run
Try using the spin only function with some water in. To see if it runs, & to wake up the machine.....
Aug 19, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
