GE Audio Conference
Problem for GE (-25001RE2) Audio Conference
Ge Television Repair
By Brad - usenet poster
Any technician who is familiar with the GE TV tuner and mpu shield
connection problem please help.  I am thinking about repairing this problem
myself.  I fix telecommunication equipment for the Air Force and have been
to electronics and soldering schools.  But, I don't know where to begin to
fix this common GE problem.  I need some advice on whether I should try this
myself or have a television repair man do it for me.  I should have all the
tools I would need.  If not at home I would for sure have it at work.  If
anyone knows how I could learn to fix this problem please let me know.  Or
if it is simple enough to just explain through an email I would really
appriciate it.  Or, if I shouldn't even try please let me know that too.
Thanks alot.
Shawn
Same Problem
Mar 08, 2009
-   27" GE TV.- Model 27GT613, I Have Problems With ONE large White Horizontal Bar Followed By Numerous Tiny Faded Black Bars Moving Up The TV Screen From Bottom To Top, along with off And On Flickering, And A Constant Steady Humming Sound In The Background Of The Volume. "I Do however have good Volume Above The Humm Sound"... This Should Be A Fairly Easy Fix For A Skilled Do-It-YourSelfer;-Should It Not??? -   Slycat422
Jan 09, 2009
-   I have a GE non plasma TV about 5 years old. The knob to screw on the antenna or cable cord is loose and not connecting to the TV. The TV turns on though. Is this something I can do myself or do i need a repairman to my house.-   jkoss
Best Solution
posted on Aug 11, 2005
Very Helpful)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
rca/ge (thompson) are the same co. They make a kit called an "s"kit . It comes
with solder and a temp plate you lay on top to show the areas that need to be
soldered. Also you need a 150 watt solder gun/iron to remove
the sheild .Thompson made the sheild out of 3 different materials ,you can try
removing it with a 35-40 watt iron but if no go it will  need more heat.
Was this helpful?
Yes
No
Solution #2
posted on Jan 16, 2009
Not Rated)
bigmacks
Rank: Apprentice
Rating: 0%, 0 votes
I have a 18 yr old GE projection 46 " that was working last time we viewed it but when we turned it on this A M it onlymade a small poping sound and never came on I winder if its worth repairing
Was this helpful?
Yes
No
Solution #3
Not Rated)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
Got there before you, Sam...
http://plop.phys.cwru.edu/repa irfaq/REPAIR/F_rcatune.html
has the information you need.
Tom
Was this helpful?
Yes
No
Solution #4
Not Rated)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
Some do's and dont's when working on these sets.
Don't : Overheat the circuit board near any surface mount components. They will
crack if they get too hot.
Do: use a good soldering station with a temperature controlled tip and good
quality 2% silver based solder, it flows better.  Removing old solder with
solder-wick allows a better connection as well.
Don't: pry down on the circuit board while removing the bottom tuner shield.
It is very easy to cut a small trace or break a component under the shield.
Do: remove all solder holding the can down and remove by gently lifting on the
shield on each of the four corners.
Do: Add additional solid #24 wire to bypass the outside grounds for when they
crack again.
Do: add additional solid wire to the can in each of the center post holes to
allow less of a gap between the board and the post.
Do: resolder the ground to the horizontal output transistor heatsink.  If it
cracks it arcs and corrupts the eeprom.
Do: when you are finished resoldering, very carefully inspect for any solder
splashes or bridges.  There are several very close surface mount parts that are
very close to the edge can.  If unsure, remove the solder and double check.
Good luck.
David
Was this helpful?
Yes
No
Popular Solutions for GE Audio Conference
Questions and Unsolved Problems for GE Audio Conference
Do you recommend GE (-25001RE2) Audio Conference?
Answer
Answer
Stopped working. No picture, no juice, no nothing. Plug is into working electrical outlet. It is 10... (More)
Answer
I have a 27" GE TV Model #27GT613, SER.#3172?7410, color has gone out, still has good picture.... (More)
Answer
We had a power surge and now the TV is flipping from one channel to the next. We can't get it to... (More)
Answer
I have a GE non plasma TV about 5 years old. The knob to screw on the antenna or cable cord is loose... (More)
Describe your Conferencing Stations problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Conferencing... Experts
Top Telephone Repairmen
in , PA
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
