Question about Sharp AR-M205 Copier
Flashing symbols Red lights are flashing on the panel just above and beside the digital number display screen. the arrow on the side that is flashing is the second one down as if to say paper is stuck there but i have entirely taken the side cover off removing 5 screws and also the other light that is flashing is the symbol right beside the 'out of paper' light, that looks like the number 8 and a squigly heart rate monitor shape line...I cannot find any paper stuck anywhere either
  • Sharp Master
  • 2,794 Answers
Is there another part to the error code besides the 8 like a letter in front of it?
Posted on Jul 18, 2008
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
My CLP-315 is flashing red! what can I do?
A red FLASHING light means there is a minor problem with the unit.
According to the manual there are two options at this point; 1. read the error on the display and solve that problem or 2. The toner is almost empty and needs to be replaced. (you can see which toner is low according to the toner status symbols on the display and just try taking that cartridge out and GENTLY shifting it from side to side a little.) You can tell which toner cartridge it is becasue there will be an arrow in the display above it. Hope this helps.
Feb 08, 2011 | Samsung CLP 315 Laser Printer
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
When i turn on my digital camera, in the upper left hand corner, there is a red, flash symbol which i don't know how to turn off??? Thank you in advance for your assistance.
You should be able to turn off your flash, or change the flash to a different flash setting by using one of the buttons on somewhere on your camera. The proper button is identified by the flash symbol, that looks the same as the one on your LCD screen, a jagged, down ward facing arrow, that looks something like a bolt of lightning. Simply press this, it will ether change the setting on your LCD, or bring up the settings that you can change manually by selecting whatever setting you want for the flash.If you don't want to change any of the settings, but want to clear the symbol off of your LCD screen simply hit the Display button that will hide those icons from your view and can be seen again simply by hitting display once more. I hope this is of some help to you, if not, consult your user guide or manual that came with the camera, it should explain exactly what to do. I hope that you have success, God bless...
Aug 16, 2009 | Cameras
Flashing symbol
This symbol means that the backup battery needs to be changed. The backup battery is a button-type battery, CR1616. It is located under the main battery behind a small square panel. Instructions for changing it are in the manual -- look under "backup battery" in the index.
Apr 06, 2009 | Canon MV800i Mini DV Digital Camcorder
Symbol figure with red arrow
It is missed call symbol. If it's an arrow symbol just above a phone receiver picture, your calls are set to divert to another number, you can correct this in call settings.
Mar 14, 2009 | Sony Ericsson W910i Cellular Phone
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
Feb 22, 2008 | Canon GL2 Mini DV Digital Camcorder
Camera problems
i have a problem when i want to take a pic of my car at night the pics dont come out that good why is that.
May 30, 2007 | DXG Technology DSC 568 Digital Camera
Sharp AR-M205 Copier Logo
168 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
