I'm trying to get on a college web site,it keeps telling me failed to initialize(ct106) error:(object error
    Novelist:
    Scholar:
  • 160 Answers
Contact the college for help. It's probably something incompatible with your browser.
Posted on Jul 18, 2008
I keep getting a error message ssl handshake
The SSL handshake is initiated when your browser issues a secure connection request to a Web server. The server sends a public key to your computer, and your computer checks the certificate against a known list of certificate authorities. After accepting the certificate, your computer generates a key, and then encrypts it using the server's public key. If the SSL handshake fails, your connection to the Web server will not be secure, potentially compromising your business communications. If you cannot make a connection to secure sites when the handshake fails, you know the handshake safeguard is working properly. Test your SSL functionality by intentionally causing the handshake to fail.
Other possilbitiy is the SSL is out of date.
Sep 11, 2014 | Computers & Internet
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
Award:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
Phoenix:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
AMI:
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Thanks
Apr 02, 2011 | Computers & Internet
Error An error occurred while loading the COM file
uninstalled the program, downloaded the latest trial version from Sony (25 da trial) and recovered the files without errors. I will try to repair my own version later.
Thanks for your reply.
Dec 19, 2009 | Sony Vegas Pro 8 for PC (SVDVD8006)
Keep getting a service error 5100 notice
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Daughter can not get laptop connected to the web from her dorm.
Its possible that the firewall on her computer stops it. The firewall may be thinking that the scan is an attack. Try disabling it.
Aug 18, 2008 | Dell Inspiron 1501 Notebook
Blazer Crashing on College Campus Wi-Fi
My initial reaction is that that does not look like a network error at all... have you tried loading the page on a different network? Have you tried loading a different page on the campus network? Errors tend to percolate through the system in strange ways, and it is still possible that a network problem is causing this, but network errors tend to look like "no DNS server," "web site not found," etc.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Computers & Internet Logo
David Payne
David Payne
