Question about Master Lock 5400d: Portable Select Access Key Storage Lock
My Brass Master Lock Combination Lock is refusing to unlock. A couple of the combo numbers seem to be "sunk in" a bit. I tried WD40 but still will not unlock and I need to open my gate. This lock is only less than a year old. Help!
  • 1 more comment
  • ccforsure Jul 18, 2008
    Unfortunately, all three of us went out to put in the "right combination".  We all use this lock daily as we enter into our backyard gate. Earlier in the day, I had heard an "explosive" sound in the area of the lock but didn't see anything. This is a 4 digit combo for the 175D, I found the packaging. Don't see how putting in the numbers the opposite way would be successful or how three of us would not put in the right combination.
    I am sorry to disagree with you and the locksmith but listen carefullly, the lock is locked onto the gate - it is closed. My packaging says that the lock combo can only be changed when the lock is OPEN. I am stuck with the lock that won't OPEN. Yes, we are using the right combo, has been the same combo for over 5 years. Yes, we have a key but that does no good when the lock is locked, and my husband does not have bolt cutters. I guess we will have to find bolt cutters and send to MasterLock.
  • Anonymous Mar 27, 2014
    Samsung gusto was searching on phone checked box marked nam 2 . mistake!it locked phone with 4 digit number tried all of carriers lock codes. did not work. need code to unlock or a way to reset phone manually.
  • 96 Answers
You need to make sure you are putting the righ combination. Try to put it the opposite way also for example
3645 or 5436
How many numbers are in the combination?...if it is a 3 number system it should be easy.
Artgirl
Posted on Jul 18, 2008
  • DASEP
    DASEP Jul 18, 2008
    175D comes with a change key. With that key you can change the combination as many times as you want. Who has the key?
    I think someone change the combination. Lock at you lock there must be a little whole on the side for that change key.
    Believe me I work in a locksmith store. I just consulted with the locksmith and we both saw the lock with the change key. Who bought the lock?
    Artgirl
I forgotten my skybag number lock how to open the lock .
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Feb 05, 2015 | Master Lock TSA Set your Combination Lock...
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
Bell 4 digit bicycle cable lock won't open
Same thing happened to me today. (Bell kevlar combo lock 12 mm) I sprayed WD4 0 on my lock (probably wasn't necessary) and let it soak in. I looked up videos online which weren't very helpful. I kept trying to open my lock and I happened to move one of the four digits and it opened. I'm not sure how the lock pins work but it seems like if you lock your bike and move the lock into ackward positions you can cause one or more of the pins to move. My combo was 2194 and I opened it with the combo of 2294. Go ahead and try your combos +/- one number at all four positions. Hope this helps.
Mar 10, 2013 | Cycling
Can not unlock combination lock of 'jeep' suitcase. Initial combo was 0,0,0. How can I reset the combination ?
What you want to do is just keep tension on the shackle, or the part of the lock that would open. With tension on it start at the opposite end and turn the numbers. You will notice that it will get "stuck" on a specific number. That's the last number in the combo. Turn the middle number till it sticks. Then the last. Tadaa! Hopethishelps
Feb 04, 2013 | Locks & Locksmithing
How can I find the combination to a master lock 1500 lock?
go buy a new lock and dont lose the combo or try a new combo everday for the rest of you life but remember to write down what you try each day or then you will be truly wasting your life away
May 20, 2010 | Garden
I foregot the combination to my master lock.
We are a company that uses these lock to show homes and we have 4 locks that we cant locate the combo to. This lock you put the key in and lock it back and it has a 4 combo but the person that handled these have left and didnt give us these combos...cant open them...any ideas on how to unlock these codes?
Jul 18, 2009 | Master Lock 5400d: Portable Select Access...
I have a master lock 1534D and can't remember the combo. How can I reset it?
Check the MasterLock web site to see if they still offer to provide for forgotten combinations. Some years ago I got a combination for a standard rotary dial lock by providing the usual identification information plus a photo of the lock showing its serial number.
Jun 11, 2009 | Master Lock 5400d: Portable Select Access...
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Mar 16, 2009 | Sentry Fireproof Safe
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
627 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
