Question about Denon Audio Players & Recorders
One speaker channel will not work - going from intermittent to completely dead.
  • Jimania Jul 18, 2008
    I'm old school (lol) - it's a Denon DRA-555 which I love. It's like an old friend.
    There was a period where it required "cheating the balance to get that channel to play and then it stopped altogether. I had switched speakers to check it and it is def the receiver.
    This unit has the A/B speaker jacks. The "A" has the dead channel and the "B" has one channel that is weak.
    Any ideas are appreciated. I'm a handy guy but this is not my thing so it's going to the shop. Having an idea of the nature of the problem and rough $$$ would be great. Thank you!
    You are the man! I bought a $10 can of contact cleaner at Micro Center, spent about 30 minutes to visually inspect the unit and apply the cleaner at the speaker balance knob and at the speaker terminals. Turned, twisted and cleaned up with a few Q-tips. Hooked everything up and now I'm back to stereo!
    Thank you very much! Outstanding advice!
    President:
  • 624 Answers
It is possible that the speaker that is intermittent is causing the problem. Try disconnecting the speaker and see if the unit stays on and plays on all other channels. If it does, then try connecting one of the other speakers into that speaker jack and see if it still plays ok. If it does, that speaker is causing a problem. If the unit still does not operate properly after disconnecting the intermittent speaker or with a different speaker connected, the problem is most likely in the receiver.
When you say it is completely dead, does that mean that after you turn the receiver on, it shuts itself back off in just a few seconds? That is the "protect" mode of the receiver. It most likely has a bad output channel in the receiver and would not be anything you could fix yourself unless you are very good with soldering and checking electronic components.
I work at a Denon authorized service center and repair between 5 to 10 Denon receivers a week. The process of fixing them is not an easy one and is not a good idea to try and do unless you have the proper training and tools. But if you are wanting to try it yourself, I could be some help for you. I would need to know the model number, probably an AVR-????
I have the schematics and part numbers available for you if you need them.
Any extra information as to how the receiver is acting would also be helpful.
Since most Denon receivers are very good and on the expensive side, they are worth fixing. A bad channel normally runs about $150 to fix, but it does depend on exactly what is wrong with it. They are never just one part that is bad, it is usually about 5 to 10 parts that must be replaced. That is why it is important to be able to check the components properly, if you miss one bad part and then turn it on, you will usually destroy the parts that were just replaced.
Let me know if you need any help or advice on how to determain the exact problem. It will require more detail.
Dave
Posted on Jul 18, 2008
  • Dave DeGain
    Dave DeGain Jul 18, 2008
    This may just have some oxidized switches and/or some bad solder joints. If this is the caseyou may get out of it with $100 or less. But that also depends on the shop, their rates, and their honesty. Without looking at it myself, I could not be certain as to the problem, there are just too many things that can cause the same type of symtoms. The balance and the speaker switches could be cleaned and fix the problem. If you get some electrical contact cleaner and spray it into those switches and then work it in for a few minutes on each switch, you just might avoid the repair shop all together. Just try to get the contact cleaner into those switches, in fact, get it into all the switches and controls. You should only need to do minimul dis-assembly for this, and the contact cleaner, if it is made for electronics, will not harm the inside of the unit. If you ever hear scratchy and crackling type of noise form the speakers, it could just be those switches and controls needing to be cleaned.
    Dave
  • Dave DeGain
    Dave DeGain Jul 19, 2008
    I am glad I could be helpful, thanks so much for the compliment and the rating.
    If you ever need any help, you know where to find me!
    Dave
My rear speakers won't work in my 2001 Malibu. Stock system and wires to speaker okay. fader set Correct. Could it be speakers are junk?
Get a known good speaker an hook it up in place of the old ones an see if it works , if it does the old one is no good . Now if it doesn't work the radio isn't set correctly or that channel of the radio is blown .
Oct 23, 2016 | 2001 Chevrolet Malibu
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Subwoofer channel no longer has output
Is your sub powered (amplifier built-in)? If so, connect your MP3 player directly to the sub input and see if you hear audio. If you do hear audio, check for cable problems from Panasonic to sub input. If the sub is unpowered then it's either the speaker wiring, an intermittent sub and/or your Panasonic at fault.
Mar 22, 2015 | Panasonic Sa-ht70 Home Theater Receiver 5...
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Mar 08, 2014 | Line 6 Flextone III Plus Guitar Amplifier
Right speaker terminal not working - tested out both speakers and they work fine when independently tested on the left speaker terminal. Sony MHC GX45 Shelf System, 2 speakers and 1 sub.
If the sound is also dead on that channel on a pair of headphones. Then you have probably lost the main power amp for that channel. To be certain. With you headphones on, slide or turn the balance control so you can only hear the faulty channel. With some music playing turn up the volume. If you can hear "faintly" music playing then the pre-amp is OK and the power amp has gone.
The power amp will be located on a heat sink. It will consist of 4 transistors (2 for each channel) or one big device (or two) (an IC). If it is transistors you only need to replace the two for the right channel.
Aug 31, 2013 | Sony COMPLETE PWB, MP-45 Shelf System
I have 3 different amps each with pretty much the same problem: One channel intermittently goes out. Power cycling sometimes recovers it temporarily. Also when I play with the input level (on the source...
I recently had a similar problem with a Technics amp having an intermittent low or no sound from the left channel. This was traced to intermittent contacts in the speaker protection relay and this may be a good place for you to start looking. Check for dry joints on the relay pc board terminals. The relays can be removed, dismantled and the contacts cleaned with a fine file and contact cleaner.
Mar 28, 2010 | Audio Players & Recorders
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Jan 17, 2007 | NAD C350 2-Channel Amplifier
160 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
