Lanier LD 135 - how do I do an OCR scan on my Lanier?
  • jeff890 Jan 19, 2009
    I'm wondering the same thing. I can succesfully scan but none of the PDF's are searchable.
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: lanier LD 325 Printing labels
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
Posted on Jul 19, 2008
  • 26 Answers
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
Posted on May 20, 2010
How can I get A Lanier LD-620C parts manual
The LD-620 appears to be a Ricoh Aficio MP-C2051 or C2551.
You should be able to find a parts list on the net. Whichever one looks the same as your lanier (who don't make anything) will be the one.
Good luck
Oct 03, 2014 | Lanier Office Equipment & Supplies
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Clean ID Sensors
Are you looking for how to clean the TD sensor???? I'm not sure what a ID sensor is??? The TD sensor is above the transfer belt unit. You will have to remove the 4 drums & transfer unit and clean the inside area of the copier. Good Luck
May 21, 2012 | Lanier Ld 425c With Df/print/scan/fax/4...
Sc 544 lanier ld 122
May 17, 2010 | Office Equipment & Supplies
113 people viewed this question
