Question about Olympus EVOLT E-300 Digital Camera
On off switch works sporatically
The off switch would not work then the on switch works intermittingly.
  • Tom O'Donnell
    Tom O'Donnell Jul 18, 2008
    The on off switch on my evolt 300 works only after waiting several minutes.
  • Tom O'Donnell
    Tom O'Donnell Jan 09, 2009
    Thanks for the help. I will see if I can fine a new switch.
    Tom
    Novelist:
  • 103 Answers
Hello odtom, Looks like you have the same problem as my Kodak. The contacts below the dial are getting worn and that's why it works intermittently. What I got for my Kodak was some electronic contact cleaner spray at Radio shack and gave it a blast. This worked for about one week and the problem returned. Other than spraying it forever, the mechanism needs the replaced. It's like an old radio with a scratchy sounding volume knob. The contacts are worn out. Time to get it replaced.
Posted on Jan 06, 2009
Intermitent sluggishness in gas peddle when driving
Have you done the engine fault code test? Have you verified the correct fuel pressure under a load? Has the camshaft timing been checked? Has the exhaust system been checked for excessive back pressure due to a failed catalytic converter?
Jun 22, 2016 | 2001 Mitsubishi Eclipse
2002 chevrolet silverado 2500 Interior lamps working intermitantly
try looking at the switch control.. it may have bad spots on it..
Dec 22, 2013 | 2002 Chevrolet Silverado 2500HD
Drive window works sporatically
Have you had your technician check the switch for loose contact??
May 10, 2012 | 2001 Toyota Corolla
Drivers side window works sporatically going up. works fine going down. Is that the regulator or motor. how do I replace it
More likely just the switch. These go out long before the motors or regulators. Start by pulling up the panel that has the switch in it. Remove the switch, and you'll find that you can take it apart in half. Do so, and clean the contacts that you find. Put it back together, and you will probably find that it works now. If it doesn't fix the problem but improves it, change the switch out.
May 26, 2010 | 1995 Buick Century
Intermitant wioer not working on 2000 mercury
this is usually going to be a problem in the on/off/inter switch, which will require replacing switch
Mar 31, 2010 | 2000 Mercury Cougar
Blower motor works sporatically
check the motor and the reisitor my bet is the motor is going bad and drawing excess voltage
Mar 04, 2010 | 2005 Suzuki Reno
My turn signal works intermitantly. It works a
Seems your flasher is going out. If i am correct the switch for your hazard lights is also your flasher. One way to find out is when it stops working tap the hazard light switch and see if it starts to work again. If so there is your problem. Hope this helps
Oct 30, 2009 | 2001 Chevrolet Impala
Power steering goes out intermittingly. Switch
I would start by doing a power steering fluid flush.
Mar 05, 2009 | 2006 Saturn ION
Cruise Control, intermitent wipers acting up.
More then likely, the switch arm will have to be replaced, everything that contyrols your wipers and cruise are built into that left arm.
I hope this helps you.
Dec 31, 2008 | 2003 Jeep Grand Cherokee
Olympus EVOLT E-300 Digital Camera Logo
74 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
