Question about Philips Magnavox 51MP392H Rear Projection Television
No picture All of a sudden for no reason the picture just went black. Still have sound. Its a Magnavox 51mp392h/17. I looked thru the trouble shoot stuff, but none of that applies. Also dont get the chanel number or the menu..nothing at all..just completely black. Any ideas?? thx!
  • Jazz617 Jul 21, 2008
    I am having the same problem.
    Please help can't afford a costly repair if its not worth it!
  • nuvia Aug 22, 2008
    make sound but picture
    Genius:
  • 1,139 Answers
Hello susbudi and Jazz617,
I would suggest do a check on the voltage from the IHVT to the High Voltage multiplier.
This will determine if this is a HV problem or not. If it is not It may be a video delivery problem which would have similar results. In any event both of these tasks I would suggest be preformed by a qualified TV repair technician.
I hope this helps,
Thank You,
Shuttle83
Posted on Aug 10, 2008
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
The tv is a Magnavox 51MP392H/17 and has sound but no picture. Any ideas?
TV is in high voltage shutdown protection mode. Check to see if Horizontal output transistor is shorted or open. If not then resolder all solder joints on HV transformer. If this does not fix it then you will need to do voltage checks off of H.O.T. and then possibly a bad HV transformer.
Apr 30, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a magnavox rear projection 51MP392H turns on no picture or sound except for a little chirping noise sounds like its coming from the inside of tv
The chirping sound is an indication of a short on the middle board--the power/deflection board.
Someone needs to open the set and check for shorted parts on that board.
I have fixed several sets like yours with this problem and usually it is either a shorted transistor or another small part on that board. These are not the most easy set to work on---the entire plastic frame with the three boards needs to be put into the service position to check and look for the trouble.
Most of the MAIN boards for this set are not available--the only real chance for a repair is to trouble shoot the center board looking for something bad there.
I am sorry if I have not given you good news--but based on your description I think your problem is on the power/deflection board.
If you have questions or need advice let me know--I am here to help people.
if this information helped you rate this solution as I do this here for free.
SD TECH
Dec 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox
Need more info, does it click on and off, make any noises, was the picture going blurry, did you just move it, was in built into a wall where it wouldn't get air to cool???
Here is what I know about the 51mp392h this is a general post below I used for some other peoples fixes without more info on yours I suggest reading thru the below and links and add more info to your post so we can trouble shoot it.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Audio only, no picture
Audio without video is usally a vertical or horizontal deflection problem with the DPTV chassis and Mag 1 chassis which is what you have. You may need a new deflection Large signal board. If you would like a link to one of those boards let me know.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp392H/17 convergetnt problems
When I turn on my magnavox 51mp392h/17 the sound and picture works but there is a sizzling sound coming from inside of the tv I looked and the sound is coming from what looks like a coil it has 4 lines coming from it 3 of which go to the color projectors and one to what looks like a transformer. Can you help me out?
Jun 06, 2008 | Televison & Video
51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Mar 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
