Question about IBM ThinkPad T30 2366 Notebook
T30 does not turn on..video is blank
I face a strange issue with T30. Most of the time when i turn on my T30, it does not turn on. only the "Power On" and "Battery" light stays on and other lights are not lit. Sometimes, however, the machine turns on properly and behanves well..i am foxed what this problem is. I have tried removing battery pack, cleaning and putting it back as well as removing RAM and reinserting it properly.
Any help or experience would be great
  • ashunidhi Jul 19, 2008
    I tried few of these things. Now the machine turns on more often but not all the time. I also noticed that if i press memory slot it come up more often. The memory is well inserted and the screw is tight as well. I cleaned up the connections throroughly as well.
    I took out the BIOS battery as well and re-inserted it. So its kinda freaky right now that it turns on some time and not other times.
    Genius:
  • 2,028 Answers
This could be a couple of different things. First, remove the battery and start with AC power only. Sometime batteries will malfunction and cause this. Second, remove the memory and try starting with one chip in, then change out the chips and try. And third, this could be that the hard drive is begging to fail. If the hard drive doesn't initialize and the machine can't read it, then it will appear to be on without running. Usually it's with the small electric motor in the drive. Next time it doesn't start, listen to see if you can hear the drive spinning, if you can't, then it's the hard drive. Run through these one at a time, if you find that one helps then you don't need to follow on down the list.
Posted on Jul 18, 2008
My ibm T30 thinkpad screen is not working
It's hard to say, but if I understood correctly, your screen still functions as long as it does not stay on for a long time.
There are three possibilities
1- Video card (If you have an external monitor, plug it in and see if the same issue occurs. If so, the video card is the issue)
2- The flat cable which carries the signal from the video card to the LCD screen. (Does moving lid only (screen) causes it to behave differently? (If so, it may be the flat cable)
3- The LCD itself (In case none of the above apply)
Mar 04, 2013 | IBM ThinkPad T30 2366 Notebook
Whenever i log on to face book i get a blank screen.
As of now,Facebook has not provided the reason for profile blanking in their Help center. You can report the issue of blank screen in this Facebook Help Center page.
Cheers.
Nov 23, 2011 | Facebook Social Network
My ibm thinkpad t30 boots up but my monitor is blank
Do you hear any startup sound when you turn it on? If there is, try hooking an external monitor. If it has good display, replace LCD, if not then it may be a videocard problem. possible motherboard replacement will resolve this issue.
May 25, 2010 | IBM ThinkPad T30 2366 Notebook
My IBM thinkpad t30 beeps 8 times at me when i go to turn it on and will not start up what is that
Video memory error. The BIOS cannot write to the frame buffer memory on the video card. Since the frame buffer memory is on the video board's memory chips then you will have to replace the entire board.
Mar 01, 2010 | IBM ThinkPad T30 2366 Notebook
When i turn it on only the battery light works what should i do and what is the problem
I just experienced the same issue and found some excellent advice when facing this symptom. Search FixYa for "Ibm t30 post beep error 1 3 3 1." It could be one of your memory boards or the memory socket itself. I pulled out the hard disk, CD ROM, and two memory boards (there is good info on the Lenovo site on how to safely do all this) . I then added back one memory board, applied power, and voila the T30 came to life. I then added the hard disk, CD ROM, and rebooted after adding each device. After adding back the second memory board, I experienced the original problem. So this memory board or the memory socket appears to be the culprit.
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
Power-on-Password Problem
press ctrl+alt+del 2 times and logon as administrator with blank password and then you can change or disable the password.
Apr 10, 2008 | IBM ThinkPad T30 2366 Notebook
Thinkpad x20
hi, first check ur lethium battery, as its responsible for triggering the power supply, secondly check your RAM , clean the contacts or try a different module,as there is no video u say,these are the two common problems for these kind of issues, let me know,
Jan 09, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
