Question about Amana Refrigerators
Have a built in with bottom freezer. freezer works great for three or four days, then coil freezes up solid. i get out the old hair dryer and in about an hour i can defrost the coil.three or four days later everythings frozen up again.need help!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
THE FREEZER STOP FREEZING AT THE TOP BUT THE BOTTOM
check the evaporator coil in the rear area of the freezer behind a panel for being iced over,if so defrost it with a hand held hair dryer,then check the defrost heater element for continuity under the coil,if this is o.k. then suspect a defective defrost control
Jul 10, 2010 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
My evaperator keeps freezing solid every 3 months
No your problem is the defrost solenoid it is not make it's function well
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Side by Side Maytag Frig/Freezer Frig not cooling
Hello momeddy41,
I'm Huuum to your rescue.
Is your freezer packed to the top, and covering any air ducts near the back of the freezer?
The freezer and fridge share the air and if the circulation from the freezer to the fridge is cut off ,
this could cause problems.
Or you may just need a shot of coolant to raise the pressure in the coil.
It's not necessarily wise to spend a lot of money on an old fridge over 7 years old.
But*** it's better to try one service call and find out if it is one of the many simple things first, as I showed you. Then you would ne saving the price of a new fridge for awhile!
That's your call.
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give me a rating before you sign off!
Bless You, Thank You, HUUUM
Sep 22, 2008 | Refrigerators
I see others have had the problem I have but where are the solutions you recommend? I have a Maytag M7DH665B2A Dehumidifier that freezes solid and has a corroded sensor that's fallen off the coils.
Hi Bonsia,
Does this unit freeze in warm weather?
How old is it?
You said, I have a Maytag M7DH665B2A Dehumidifier that freezes solid and has a corroded sensor that's fallen off the coils.
My recommendation is replace it!
Here is an interesting article I just read!
.Repair or replace?
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 22, 2008 | Maytag M7DH45B2A Dehumidifier
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Aug 08, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Need Help!
i would really have to say yor thermostat is faulty now
if its freezing up top and not down low
Jul 19, 2008 | Frigidaire FRT21P5A Top Freezer...
Bottom freezer coils freezing up
DEFROST PROBLEM CHECK YOUR DEFRST HEATER,DEFROST T-STAT=LOCATED BEHIND THE PANEL BOTH ARE LOCATED ON THE COIL WITH A OHMETER OR DEFROST WITH HAIR DRYER IT WILL HELP FOR 10 DAYS OR SO.
Jun 25, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
98 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
