Question about Kenwood KDC-MP232 CD Player
Kenwood kdc-mp232 not turning on
We unplugged the radio and when it is plugged back in, the unit will not turn on and the display will not light up. there is a red blinking light behind the faceplate that is still flashing
  • gregruttle Jul 30, 2008
    Thanks for the info. There was actually a fuse in the engine compartment fusebox that was shot and i think one of the rear speakers were shot. All is good now. Thanks for your help!
  • Anonymous Oct 27, 2008
    I took this radio out of my car (93 Bonneville)nad put it into my step sons car(94 T-Bird) now it will not turn on....
  • 138 Answers
Check your connections. i believe only the standby wire is connected.. or the built in amplifier detects a short on the speaker wires.
Posted on Jul 18, 2008
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
On my pt-50lc14 hdtv my screen is stuck on this message, 5v eeprom), 3.3v (gc2), tv-factory mode
Have you tried any of the reset commands?
Try these....please let me know the result:
Method 1
1. Unit power must be ON and unit must be in STOP mode.
2. Press and hold [CH UP] and [CH DOWN] ON THE UNIT for over five seconds. The unit will turn off.
3. Press [DVD POWER] to turn the unit on.
Method 2
1. Press [STOP, TUNE MODE] on the main unit and [>10] on the remote control at the same time for about 3 seconds until the message "Initialized" disappears from the television screen.
2. Turn the unit off and on again.
Method 3
While the unit is off, press and hold [VOLUME +], [OPEN/CLOSE] and [POWER] on the main unit at the same time for more than 5 seconds.
Method 4
While the main unit is on, press [POWER] on the main unit for more than 4 sec. (All the indicators will blink twice when the main unit is reset.)
Another possibility is to unplug the power cord......wait 30 minutes and plug it back in, possibly repeating the steps above. (Method 1 should reset the unit but maybe trying each of them may be necessary until it is reset.
The message appears to be one that displays when the unit is in a setup mode.
Thank you for your reply.
Jan 02, 2014 | Panasonic PT-50LC14 50" Rear Projection...
My sony kdf E55a20 does'nt come on ,has two red light's on blinking, the other not
the set may or may not have the self check feature--set off with the Sony remote hit display, 5, vol down and power.
Oct 29, 2012 | Sony KDF-E55A20 55 in. LCD Television
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Code for kenwood car stereo kdc- mp232
showing "PROTECT" ON DISPLAY WHEN POWERED ON
Mar 18, 2010 | Kenwood KDC-MP232 CD Player
Kenwood kdc mp 232 how do I get to the aux when
turn the ipod off why would you want it on not listening to it anymore?
Jan 15, 2010 | Kenwood KDC-MP232 CD Player
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
How do i hook up a ipod to the cd player
Go here:
http://www.crutchfield.com/S-j3EX2WZGpxL/p_113MP232/Kenwood-KDC-MP232.html?tab=features_and_specs
You can download the manual and specifications.
Oct 06, 2009 | Kenwood KDC-MP232 CD Player
How do I enable the Auxillary option on my KDC-MP232 so I can play my MP3 player. I hooked it up using the aux. jacks in the back but it just played over the radio or cd player I do not know how to isolate...
when your car is on, turn the stereo off. you should be able to access a menu somehow when the stereo is off. in that menu, you should have the option to toggle the aux source on or off. simply switch it to on, then turn the sterreo back on, and hit the source button. it should now be ready to go.
Sep 10, 2009 | Kenwood KDC-MP232 CD Player
Kenwood KDC-MP232 CD Player Logo
201 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
